![]() Join Date: Mar 2013
wrong rpm?
hey guys, a question! (no shit!) my car's rpm gauge (the dash one) started showing 500-1000 rpm more than real. i see on my commander that i have for example 1000rpm idle, and the dash says 2000...besides i can tell by the sound too. it happened before for a trip then straightened itself out. now here it is again. is it a cable , somewhere rubbing or something? i guess ecu to dash?
![]() Join Date: Jun 2003
Trader Rating: (129)
its not a mechanical tach. the instrument cluster gets a signal from the ecu.
the ecu gets a signal from the distributor if you have a KA, but seeing as you're in greece you probably have a CA or SR? the SR and CA use a cam angle sensor (cas). are you using a power fc? |
![]() Join Date: Dec 2006
Probably the gauge itself. Pretty common for S14s to do that.
You can reflow the solder points on the back of the gauge that the screw go into in hopes that fixes it.
![]() 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
driving home today i noticed a method to this madness...
the gauge rpm are twice the real ones! 1000 rpm = 2000rpm 3000, = 6000 my car is learning multiplication tables it seems. |
![]() Join Date: May 2009
Hopefully it does not achieve sentience anytime soon.
Sileighty_85 knows his stuff here, he pretty much started the discussion on Zilvia of fixing the issue rather then replacing the tach.
![]() Need to adjust your idle? http://zilvia.net/f/s-chassis/395413...-pictures.html |
i removed the dash and resoldered everything behind the gauge.
i would say it did SOME difference,but not fixed it. now it sometimes works fine, sometimes x2 and sometimes something in between. i've noticed it jumping around while sitting at a traffic light. there's a big resistance behind the gauge, could it be knackered? should i try to replace that one? if that doesnt work i'm tossing it and replace it with a Koso motorcycle thingy, my mate's got one and it's excellent ![]() |
found the cause of my woes. there's a plug near the ecu at the passenger footwell that was loose. when you wiggle that, the rpm's bounce all over the place. tie wrap remedy, all ok.
Tags |
dash, electrical, rpm, s13 |
