Old 10-10-2010, 07:58 AM   #1
2402NV
2402NV's Avatar
2402NV is an unknown quantity at this point
Question on safc2
I've searched around an could only find diagrams for installing on s13 motors. I have an s14 motor, is installing the same method? If not can anyone direct me to a diagram? Thanks.
2402NV is offline   Reply With Quote
Old 10-11-2010, 04:11 PM   #2
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
What engine do you have? Because I went to the apexi website and printed out the diagram and there's no diagram on there site for the KA
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 10-11-2010, 04:21 PM   #3
fullthrottle
fullthrottle's Avatar
fullthrottle is an unknown quantity at this point
All safc-2's connect to the same wires on all cars. you just have to know what wires those are. Like maf signal rpm signal throttle position and all that. You need a wiring diagram for your ecu and then you just splice your wires from the safc-II into those wires. All except the maf signal which you want the safc-2 to be a part of the circuit so you have to cut the maf wire and run the wire attached to the maf into your safc and then one of the wires coming out of the safc goes to the wire for the maf that was cut and goes to the ecu basically putting the safc between the maf and ecu. ALL OTHER WIRES JUST GET SPLICED ONTO THEIR RESPECTIVE WIRES
fullthrottle is offline   Reply With Quote
