Old 03-28-2019, 11:41 AM   #1
240sex_s14
240sex_s14's Avatar
240sex_s14 is making a name for him/her self240sex_s14 is making a name for him/her self
Send a message via AIM to 240sex_s14
Flex-Fuel Kit for 240sx
Hello,
I've been looking around and can't seem to come across any detailed Guide for making any 240sx Flex-Fuel Compatible by replacing every line. If anyone would like to Chime in on this topic, I would really appreciate it.
I'm Looking to swapping my 98' Fuel lines to be 100% Flex-Fuel Worth and I'm seeking
-Lines to Replace
-Length of Lines
-Fittings
-Fuel Pumps
-Fuel Pump Hangers
-Best Brands to go with
Etc.
I will be making a detailed guide to doing this at the end, as I'm in the middle of my 2J swap to be completed.
Thanks!
Check out my Build Thread!http://zilvia.net/f/showthread.php?t=650464
240sex_s14 is offline   Reply With Quote
Old 03-28-2019, 12:02 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
I dont know about lengths, but I know AN fittings direct sells braided lines and fittings for great prices and great quality. I’d buy a good amount of -6an braided line and an assortment of different AN fittings (male, female, different angles and whatnot) and seeing what works best for your setup.
nisileighty is offline   Reply With Quote
Old 03-28-2019, 01:57 PM   #3
240sex_s14
240sex_s14's Avatar
yeah that's exactly what I'm going to have to do. I know there's Kits online but run from 600-1000.
I'm going try my best and do a Self-Bought / Install guide.
Was hoping someone has pre-setups already that can chime in with their knowledge.
Old 03-29-2019, 05:22 AM   #4
s13silvia123
s13silvia123's Avatar
braided lines are not going to last. even the compatible hoses. due to time ethanal will eat them up. so you'll have to replace them every year. when i went to a specialty shop that sells only hoses to fittings especially for everything imaginable, i was told that using 1/2" hardline is the best way to go. don't waste your time on braided
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
