Old 05-10-2015, 11:53 AM   #1
CaTalyst.X
CaTalyst.X is an unknown quantity at this point
Radiator help! What the heck is this?
Hey all. I bought an S13 w/ an S14 SR20DET and it came with this blitz radiator and a universal flex a lite 15" 2800cfm fan. I had some problems with overheating in the past so I was looking into different fan setups, and I noticed that this radiator doesn't look like a normal sr20det radiator. Most of the SR rads have mounting tabs on the bottom, and mine does not. Even the pictures of other Blitz LM radiators I have found for the SR20 have the tabs on the bottom. This radiator bolts right in the factory location. Could it be out of a different nissan? Any help would be greatly appreciated.
CaTalyst.X is offline   Reply With Quote
Old 05-16-2015, 05:31 PM   #2
SidewaysS13ka
SidewaysS13ka's Avatar
SidewaysS13ka is an unknown quantity at this point
was your car ever wrecked in the front end, if your rad support is tweaked, the upper mounts wont line up or sit crooked, and you should have the tabs on the bottom of the support unless the other owner cut them off for whatever reason. i have a mint clutch fan with out the clutch hanging up in my garage, if you decide to go that route. pm me if thats what you decide
Leaks,Creeks,Squeaks, and other random problems. Yup you own a 240.
SidewaysS13ka is offline   Reply With Quote
Old 05-16-2015, 05:42 PM   #3
thegr8one013
thegr8one013 is an unknown quantity at this point
take a picture of the bottom, maybe we can notice something like if it was modified and removed
thegr8one013 is offline   Reply With Quote
Old 05-16-2015, 05:44 PM   #4
SidewaysS13ka
i like his idea, because your rad has the posts on the bottom to sit in the tabs on the rad support.
Old 05-16-2015, 06:04 PM   #5
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
He's not saying anything about the chassis... He's saying every other radiator he's witnessed, has had tabs on the bottom.
I'm no radiator expert but it is possible this was from another vehicle, and has the same layout as the sr20 ones do. If that's all you're asking.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 05-16-2015, 07:43 PM   #6
wussmonster
wussmonster is an unknown quantity at this point
If you're over heating, go back to a stock fan shroud and clutch fan. It cools better than an efan setup.
wussmonster is offline   Reply With Quote
Old 05-16-2015, 08:55 PM   #7
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Shouldn't matter, stock fan and shroud or open e fan setup. It shouldn't over heat either way. I have an electric fan with no shroud and it has never overheated.
If it is overheating then that's an obvious sign something else is wrong in the cooling system, although again, I don't think that's what he's getting at people...
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 05-16-2015, 11:31 PM   #8
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
If you guys zoom in on the first picture and look at the bottom of the radiator, you can just barely see the bottom post.
They do appear to be in line w/ the top post.
It would also help if the OP would respond to some of these responses.
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
