06-16-2005, 05:44 AM | #1 |
Auto-RX in a KA24DE
I was thinking about doing this to my car and upon doing some search found this guys site.
http://www.rms13.com/ Dunno if it's a repost. It's kinda recent.
My 240 vBgarage |
06-16-2005, 05:58 AM | #2 |
This is some crazy shit. I dont know to believe it but it seems pretty legit yet im not a chemist or have a phd in something related. Why not give it a try. Seems worth it. Its worth the read and browsing around atleast. Check the engine pictures on the site last one looks like a engine that has been babied forever.
This is a 93 240sx. BEFORE:-------------- READINGS AT 121,893 MILES (PREAUTO-RX) Compression: Cylinder 1-117psi Cylinder 2-120psi Cylinder 3-117psi Cylinder 4-119psi Idle Oil Pressure: [email protected]@190degrees fahrenheit (coolant temp) Ambient Temp: 97 degrees Hot Idle RPM (A/C off): 680rpm AFTER:---------------- READINGS AT 129,136 MILES (~7000 miles w/Auto-Rx) Compression: Cylinder 1-170psi +53psi Cylinder 2-168psi +48psi Cylinder 3-158psi +41psi Cylinder 4-173psi +54psi Idle Oil Pressure: [email protected]@180degrees fahrenheit (coolant temp) Ambient Temp: ~70 degrees Hot Idle RPM (A/C off): 730rpm Last edited by m0rex; 06-16-2005 at 06:18 AM.. |
06-16-2005, 06:05 AM | #3 |
My 240 vBgarage |
06-16-2005, 06:11 AM | #4 |
They claim that you get better emissions too. Smog tech should grab some and verify.
My 240 vBgarage |
06-16-2005, 10:16 AM | #5 |
I've heard good stuff about it. I'd proceed on any oil additive with caution though. If you do decide to do it, let us know if it makes a difference.
SOLD: 91 240SX Coupe SR20DET, 05 Evolution 8 NEW: 08 Evoluton 10 |
06-16-2005, 10:35 AM | #6 | |
http://auto-rx.com/cart/order.htm $24.97ea. for one bottle, or $18.97ea. for six bottles. |
06-16-2005, 05:59 PM | #9 | |
AFC #1
06-16-2005, 09:35 PM | #10 |
$4 coupon here too:
http://www.auto-rx.com/arxfq.htm It is supposed to give you better gas mileage by cleaning out the inside of the motor. I just ordered a bottle of this stuff. I'm going to try the "maintenance" program.
06-16-2005, 10:28 PM | #12 |
Not two bottles .. two applications. 1 12oz bottle is for 6 quarts of oil.
The KA only takes about 4 quarts so you can probably two 2 cleanings from 1 bottle.
06-16-2005, 10:36 PM | #13 |
^^That's what I'm going to do.
My 240 vBgarage |
06-16-2005, 10:39 PM | #14 |
from Canada, eh!
I had similar results with a good synthetic oil like Motul's or by using Motul's engine cleaner.
-> HaLo Race Car: '98 E36 BMW M3 Daily Driver: '08 Fiji Blue Honda Civic Si SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
06-16-2005, 10:56 PM | #16 |
Actually, running Redline for 3 changes got mine looking pretty darn clean. But I think I'll still try it.
My 240 vBgarage |
06-17-2005, 12:07 AM | #17 |
I've used something like that in my civic engine called clean power. Comes in a 2 liter bottle for about $15 at Winchester Auto. I would put in about a quart. Can't remember what the recommend dose was. I put it in before I change the oil and run it for about 5-10 mins. Then drain oil hot and refill. The next time I took the valve cover off, it was clean inside the head. So stuff like that works. But I guess it depends on how dirty the engine is.
I'm driving fast -drew |
06-17-2005, 11:53 AM | #19 | |
my SR only has around 55k on it...but the valvetrain looks immaculate compared to his after pics...i didnt even know engines got that dirty as in his before pictures
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
06-18-2005, 09:09 AM | #20 |
wow i thought my engine looked dirty when i tore it down last week but DAMN that guys was a mess...it looks like he never changed the oil in that thing. ever.
since my engine isn't much dirtier than his *after* shots i guess i'm not gonna chance it with this stuff... on a side note, i do worry about strong detergents and degreasers inside my engine...if your motor is in bad shape its worth a try, but i wouldn't chance it until we get some good rock-solid evidence....
06-18-2005, 02:09 PM | #21 |
bah.. drain motor oil, run 4 qts of atf, let idle for a few minutes, drain, then put new motor oil.
Then run atf thru the brake booster and thru vaccum lines, make sure car is warm and running, set car off for 15 minutes, then start up and watch all the smoke. Simular to seafoam.
Keep it Classy |
06-19-2005, 12:44 AM | #22 | |
You dumbass you don't run 4 quarts of ATF!!! Besides you used that sea foam shit. I used the ATF trick you roughly let a vacuum line suck up about 1/4 qt. of dexecron 3 (sp?) and let it ilde for an hour, and it will smoke for a solid hour. Note: make sure to have fresh oil and plugs ready to change after the treatment.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 |
06-19-2005, 01:31 PM | #24 | |
Keep it Classy |
06-20-2005, 02:00 AM | #25 | |
06-20-2005, 03:15 AM | #26 |
Tone it down a notch foo.
My 240 vBgarage |
06-20-2005, 07:46 AM | #27 | ||
AFC #1
STFU both of you.
Comments should be taken as Opinions not as Statements of Fact |
06-20-2005, 07:50 PM | #28 |
I'm on the second cleaning cycle of auto-rx right now. To be honest I haven't notice a difference but it was recommeded to me by a co-worker so I figured why not since I had over 130K on my engine. Also the instructions says to use 10oz for a 4 cylinder and the whole 12oz for a 8 cylinder.
06-21-2005, 10:13 AM | #29 |
I got my bottle yesterday and the directions say 2oz for every quart of oil you fill so should be more like 8oz if you are going by directions.
I am not doing the full clean because the engine was recently rebuilt and should be really clean already. Just doing the maintenance program which is 2-3oz every oil change. The Auto-RX isn't a normal cleaning solvent and doesn't harm anything in the engine. Which is why it works slowly over several oil changes. Who knows? A lot of the stories about Auto-RX sound like miracle stories... almost too good to be true. It fixes leaks, improves compression, better gas mileage etc.
