Old 05-10-2011, 11:08 PM   #1
RyanS13
RyanS13's Avatar
RyanS13 is an unknown quantity at this point
Pilot bearing issues.
So I just found out ever since I put my rebuilt KA in my car about 20,000 miles ago it had a pilot bearing.
Since the rebuilt motor has been put in its been through 2 clutches, and now the transmissions done.
So I went to install the pilot bearing today and it wasn't going in very easy but I got it in. I made sure the pilot bearing would slide on and off of the transmissions input shaft before I installed it.
Then I went to push the clutch alignment tool in to check it out and the clutch alignment tool wouldn't go in, the pilot bearing whole was too small.
I then chiseled it out into pieces and went to nissan to get a new one, and measured the diameter of the outside of the pilot bearing and its at .812.
Then I went and measured the inside of where its supposed to go and its at .752.
What's going on here? And what could I do? I have access to a lathe that I could trim it down some, but I'd rather know why its like this.
RyanS13 is offline   Reply With Quote
Old 05-10-2011, 11:15 PM   #2
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
whats the part # you have? if its a new transmission whats it from? and fyi its a pilot bushing if its the brass looking one.... (just correcting terminology, not being ass-hat).
Originally Posted by Your240sucks;
Dont really want to lowball you but Will you pay me too pick it up?
r20crazy is offline   Reply With Quote
Old 05-10-2011, 11:23 PM   #3
RyanS13
RyanS13's Avatar
The transmission is from a KA24DE too.
And the part number is 32202-B950A
haha yea its that little brass thing.
Old 05-11-2011, 01:20 AM   #4
hessianben
hessianben is an unknown quantity at this point
do one this:
Nismo Pilot Bushing -Needle Bearing
hessianben is offline   Reply With Quote
Old 05-11-2011, 01:28 AM   #5
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
I've heard really bad reviews coming from the needle bearing. OEM is the way to go IMO.
SLiDe_WaYz is offline   Reply With Quote
Old 05-11-2011, 01:56 AM   #6
RyanS13
RyanS13's Avatar
Originally Posted by hessianben View Post
That thing looks real nice, just don't think it will solve my problem though.
Old 05-11-2011, 02:05 AM   #7
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
Its supposed to go on pretty tight. When you hammer it in, it mushrooms in a way(if you get what I'm saying) causing the alignment tool not to go in. What I did was take some sand paper and just smoothed the inside until the alignment tool fits perdectly
R@ddy is offline   Reply With Quote
Old 05-11-2011, 10:42 PM   #8
RyanS13
RyanS13's Avatar
I'm starting to think theres a Auto transmission bushing in there that came with the motor when I bought it.
Old 05-12-2011, 12:16 AM   #9
r20crazy
r20crazy's Avatar
Trader Rating: (41)
pm me your #. if u still have the blitz nurspec ill trade u figuring out whats wrong for it.. if u've had the motor bolted to a manual trans b4 and it worked at all there is no auto trans adapter bushing in the crankshaft
Old 05-12-2011, 12:43 AM   #10
hessianben
i haven't heard...? what's being said so far?
haven't had any troubles with mine for about a year now.
Old 05-12-2011, 12:47 AM   #11
SLiDe_WaYz
SLiDe_WaYz's Avatar
I've seen guys threads on here who have used the needle instead of OEM, and the input shaft just busted the needle pilot bushing up causing the shaft to rattle around.
Old 05-12-2011, 12:13 PM   #12
RyanS13
RyanS13's Avatar
Not true man. I pulled out the auto bushing this morning in like 5 mins, then tapped the new pilot bushing in, and the alignment tool fits just fine in there now.
