Old 01-13-2013, 04:58 PM   #1
todd5854
todd5854 is an unknown quantity at this point
Integra gauge cluster in S13
I know someone will put me on blast for even thinking of this.
I thought it would be cool to put the Integra gauge cluster in the S13, I think the cluster looks sweet, more appropriate for the car. Also the grey matches my custom interior.
If you think its stupid then fine, but would it be possible?
I know the s13's use digital speed sensors, and so do the DC series Integras. Any idea if this would be a direct connection? If I get no answers, I might just have to try it myself..
todd5854 is offline   Reply With Quote
Old 01-13-2013, 06:27 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Issue you'd have is that the voltage needed by the cluster to work properly will probably be off. Just cuz you can wire it in doesnt mean itll work like intended.
CLICK HERE!!!
Old 01-13-2013, 06:53 PM   #3
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
Only issue you might have is fuel level gauge. Temp sensor from Integra and maybe Dakota digital box to correct speedo.
Dummy lights are easy to wire up.
Tach is a 4cyl signal for both.
Give it a shot, see how much of it u can get to work. I think you'll.be able to get most of it g working
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 01-14-2013, 05:28 AM   #4
Akito86
Akito86's Avatar
Akito86 is an unknown quantity at this point
I say try it hey who knows could work gl !
☆*Nissan-RPS13☆Nissan 350Z*☆ ☆*Toyobaru FRS☆Toyota XB*☆ ☆*o(≧▽≦)o*☆
Akito86 is offline   Reply With Quote
Old 01-14-2013, 08:49 AM   #5
todd5854
I think I'm gonna try it. My only worry is different resistance on the fuel gauge, and the speedo. If I find a cheap cluster, I may have to try it!
Old 01-14-2013, 09:06 AM   #6
Daviticus
Daviticus is an unknown quantity at this point
As far as the fuel gauge, it may work pretty well. According to the FSM, on an S13 the fuel level sender's readings are as follows:
Full - 4-6 ohms
Half - 30-35 ohms
Empty - 80-84 ohms
And on a Honda [this is for a CRX, but almost all H-cars have the same reading]:
Full - 2 - 5 ohms
1/2 - 25.5 - 39.5 ohms
Empty - 105 - 110 ohms
As far as a temp reading, you could just use a Honda CTS and wire it directly to the cluster.
After that, you'd only have to deal with speedometer PPM [pulses per mile], but a Dakota Digital speedo converter box can handle that easily enough.
- Welp, that blowed up real good. -
Daviticus is offline   Reply With Quote
Old 01-14-2013, 10:27 AM   #7
todd5854
Full - 4-6 ohms
Half - 30-35 ohms
Empty - 80-84 ohms
Full - 2 - 5 ohms
Those Dakota speed boxes are like $85 ish though, right? :/
This is not that important to me, haha I was looking to spend like $50 for everything.
Old 01-14-2013, 01:25 PM   #8
Sir
I just got one from here for $60. So you can find them for cheaper, search the cl
Old 01-14-2013, 02:47 PM   #9
Daviticus
Yeah, here and eBay are your friends. Just gotta be a bit patient sometimes.
Old 01-14-2013, 09:49 PM   #10
todd5854
I'm surprised someone didn't call me a dumbass for wanting to try this.
I searched and searched, no one has attempted this before. If I actually do it and its not a flop I'll be sure to write it up.
Old 01-14-2013, 10:04 PM   #11
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
i'm not against the idea, but i would have rather you already DONE the swap, THEN made the thread.
there are too many threads about "hey can i put xxx into yyy???" that never go anywhere.
i just finished putting a kouki 180sx blacktop into my brothers nissan frontier pickup, and making the frontier cluster work with the sr ecu wiring was time consuming, but it worked out perfectly.
Old 01-14-2013, 10:16 PM   #12
Sir
Nothing in the cluster is ran from ecu except an cel idiot light and they are all just a simple bulb circuit
