Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
06-20-2004, 11:10 PM | #1 |
Frist time at the strip w/ my s14
Well I went on saturday to the drag strip. This was at Beaver Springs Drag Strip. A local shop out of Dillsburg (Dynamics Motorsports) Rented the track. You could make as many passes as you felt like for 30bucks. All in all I had an impressive day, being the second fastest street car their. I made around 13 to 15 passes, I'll post up my best with stock boost, low boost, high boost. Didn't play with tires at all, should have dropped the air pressure, totally foregot about doing that. I had 17's on the front with brand new kuhmo escta's 215/40's 17's on the back I had the stock 16's with like 38lbs of air in. On the reaction time, a perfect is zero's across the board.
Temp. was around 78degrees. Stock Boost runs: 7lbs R/T: .514 60': 2.914 1/8: 10.533 mph: 75.99 1/4: 15.577 mph: 99.18 R/T: .204 60': 2.926 1/8: 10.621 mph: 77.92 1/4: 15.506 mph: 102.69 Low Boost: 10lbs R/T: .308 60': 2.696 1/8: 9.516 mph: 81.46 1/4: 14.266 mph: 104.99 R/T: .047 60': 2.441 1/8: 9.264 mph: 81.44 1/4: 14.002 mph: 101.90 R/T: .017 60': 2.887 1/8: 9.751 mph: 81.19 1/4: 14.525 mph: 104.35 High Boost: 14lbs R/T: .233 60': 2.325 1/8: 9.021 mph: 81.96 1/4: 13.749 mph: 105.52 R/T: .298 60': 2.108 1/8: 8.759 mph: 82.25 1/4: 13.468 mph: 102.38 I'm going to be going back to the track next month, but i'll have a Greddy intake manifold on and have the cat, taken out and have a 3'' piece of pipe put in and have my 550cc Nismo injectors on with a z32 MAF.
06-21-2004, 05:42 AM | #3 |
Yep, it was my first time, with my S14. when I went up I made sure, to burn out in the water, get about two full rotations with the tires in the water, and make sure you reach second gear. Then stop really quick, and burn out a lil' again to get the water off.
07-13-2004, 11:47 PM | #4 | |
if you're running on street tires try to avoid the water completely and just do a little burnout to get any stuff off ur tires before you make ur pass,,, that will help your 60ft time a lot I think.
07-14-2004, 07:27 PM | #5 |
if your running street tires, burning out only makes them grip less, and running 38 psi cold doesnt help much either, your 60 ft shows just that,
Drift_ Into A Mountain Jim Wolf Technology Stock CA18DET-SR T25-greddy FMIC-JWT SR Lightened FLywheel-300zxTTclutch-SR20DET JWT tuned Ecu |
07-15-2004, 11:10 PM | #6 | |
its still a good idea to do a quick spin to get any crap off ur tires,
Also to help with launches, pull off the front sway bar next time you go to the track,
07-18-2004, 08:32 PM | #7 | |
Wow thats good for little mods like that
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got |
08-04-2004, 05:44 PM | #8 |
should be ETing in the low 13s with 105 MPH. work on those 60 ft. times. i agree if on street tires, no water... jsut one lil spin to get crap off tires.
08-04-2004, 09:57 PM | #9 |
i see on your stock boost you were running 10.5-10.6 in the 1/8th i ran a 10.9(1/8th)with my stock ka deff. should have deflated the tires and like they said avoid the water on street tires
