Old 07-20-2008, 10:54 PM   #1
sanshou2
sanshou2 is an unknown quantity at this point
speedometer inaccurate
Hi, i just bought a 1990 240sx, when i'm in fifth gear doing 60-70 on the freeway the speedometer needle goes past 115 and stays there. It also jumps around once in a while. I have checked the VSS sensor and it gives about .6v AC volts. Could that be the problem or is it in the speedo cluster itself?
sanshou2 is offline   Reply With Quote
