Old 01-08-2013, 06:27 PM   #1
slide2unlock
Trader Rating: (-1)
slide2unlock is an unknown quantity at this point
Feedback Score: -1 reviews
how to tell what head gasket i have
i have an s14 sr20det, perfect compression, im at like 290whp, how do i tell what kinda of head gasket i have? its got like 2 little metal nubs sticking out of the block, i will post a pic shortly. and what does stock look like?
slide2unlock is offline   Reply With Quote
Old 01-08-2013, 06:33 PM   #2
Sileighty_85
Sileighty_85's Avatar
if its metal with a little rivet in the middle its a Metal HG, OEM doesnt have these tabs.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-08-2013, 06:36 PM   #3
Jersthecool
Jersthecool is an unknown quantity at this point
Mine says cosworth sticking out the front but if you only have 2 nubs sticking out my best advice is to google pictures and compare if they stick out in the same spots and if the headgasket is silver or black. Other than that there's no real way unless you pull the head off.
Jersthecool is offline   Reply With Quote
Old 01-08-2013, 11:03 PM   #4
slide2unlock
Trader Rating: (-1)
this is it, idk if it attached but those little metal nubs
Old 01-08-2013, 11:52 PM   #5
Sileighty_85
if thats the only tab you have then its OEM.
後輪駆動車1番
1986 SR86 - 200ish
Old 01-09-2013, 12:06 AM   #6
slide2unlock
Trader Rating: (-1)
o_O and im making 300hp on an oem gasket. this is no good
