Old 07-06-2011, 08:37 PM   #1
eliminator024
eliminator024 is an unknown quantity at this point
s13 please help i only have air blowing out of the defrost vents!!!!
i have a 1990 Nissan 240sx it only blows air out of defrost no where else and i cant stand this California summer heat lol, can someone please help me out on how to fix the problem. Also the light to the a/c button does not come on i dont know if it works or not or has anything to do with the problem.
eliminator024 is offline   Reply With Quote
Old 07-06-2011, 08:40 PM   #2
jesse_s13
jesse_s13's Avatar
jesse_s13 is an unknown quantity at this point
Have you checked to see if the ac compressor turns on?
jesse_s13 is offline   Reply With Quote
Old 07-06-2011, 08:42 PM   #3
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
check the fuses!
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 07-06-2011, 09:28 PM   #4
AutechKouki
AutechKouki's Avatar
Trader Rating: (43)
AutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura aboutAutechKouki has a spectacular aura about
Feedback Score: 43 reviews
Defrost vent might be air vent servo motor being out, and your compressor not turning on is most likely low refrigerant charge or no refrigerant at all.
AutechKouki is offline   Reply With Quote
Old 07-07-2011, 02:29 AM   #5
eliminator024
s13
Its not the fuses or the compressor its something else causing it to only blow from the defrost vents, checked the fuses there fine. I was using the heater last year and all of the sudden it only blew through the defrost only so idk what broke.
Old 07-07-2011, 03:11 AM   #6
mad-ass
mad-ass's Avatar
your hvac unit maybe dead is no longer telling the vent arms to move to correction position when position selector is pressed.
Old 07-09-2011, 07:35 PM   #7
eliminator024
So I need a new control unit the conrtol part by my radio and it should work??
Old 07-10-2011, 03:17 PM   #8
mushmonster
mushmonster is an unknown quantity at this point
With a test light check power at the mode door servo (driver side-right of gas pedal) when actuating each mode if no power, may be control head or power from 10A fuse at drivers side kick panel. No ac light may mean issue at the relay(drivers side engine comp fuse block), wiring, or control head. check for power at ac clutch on compressor.
mushmonster is offline   Reply With Quote
Old 07-13-2011, 10:02 AM   #9
jaked23
jaked23 is an unknown quantity at this point
the air ven doors are ran by vacuum. you probably have a vacuum leak somewhere. when there is a vacuum leak, it defaults to defrost
jaked23 is offline   Reply With Quote
Old 07-20-2011, 12:26 AM   #10
eliminator024
Where are the vacuum lines under the dash?
