Old 03-16-2010, 09:39 AM   #1
wjs1122
wjs1122 is an unknown quantity at this point
Unhappy need harness plug for turn signals!
95 s14
long story short most of the turn signal and side marker male plugs off the harness got broken off.(again that's the plug from the harness that goes into the turn signal bulb). can you buy replacements or anything? or any hard wire tricks??, any help appreciated
THANKS!
wjs1122 is offline   Reply With Quote
Old 03-16-2010, 11:48 AM   #2
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
Genuine Nissan Parts :: 240SX Parts (S14) 1995-1998 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
Look around on there you should be able to find it.
Daily driven
jspaeth is offline   Reply With Quote
electrical, tech, turn signal, turn signal help
