Closed Thread
Old 04-04-2012, 05:23 PM   #1
nissanduster
nissanduster is an unknown quantity at this point
Sr20det vs. Rb26dett
I'm tring to beside on the two engines I did my share of research on both engines and I like both. I know the sr20 is cheaper depending on the engine and I know the rb26 is about the same as the s15 sr20. I would like to have alot of power so the rb26 would be a good engine to get but I know the sr20 can push alot of power also.
I would like to know what everyone thinks on there engines, tell me the pros on cons on your engine. Any sr20s, rb26dett or rb26det and any mods you have done.
Thanks
nissanduster is offline
Old 04-04-2012, 05:53 PM   #2
Okinawandrifter87
Okinawandrifter87's Avatar
You should know by now that this has been covered.. use the search button or google.. youll actually learn a lot more there first then just sitting waiting around for someone to actually answer you.. on that note.. this thread will need to be locked so you can go search. Dont expect to be spoon fed.
Driftphreak87
Okinawandrifter87 is offline
Old 04-04-2012, 05:55 PM   #3
Jtuned_andy
Jtuned_andy's Avatar
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
I hate telling people this because it makes me sound condescending but really if you have to ask these questions you should take the easier road. I bought my first nissan and swapped an RB20det into it, I asked ZERO questions on the internet about my swap even though I had no idea what I was doing other than just droppping the engine in. It takes HOURS of research to figure out what is best for you. Nobody in here with an opinion worth two cents is going to answer this question for you, gotta learn for yourself.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline
Old 04-04-2012, 06:38 PM   #4
S14DB
AFC #1
S14DB's Avatar
S14DB is offline
Closed Thread
