Old 04-29-2020, 10:21 PM   #1
MEEPER278
MEEPER278 is an unknown quantity at this point
Weird burning smell!
Hello everyone, around christmas, i got an '89 hatch with a dual cam swap. I've had no issues with it until recently, i have smelled something burning and and sometimes smoking. Before you comment "head gasket" it's not that. There is light smoke that comes out of the engine bay for only about 5 seconds, my coolant isn't mixed with my oil, and there is no smoke from my exhaust. The car runs fine. The smell isn't coolant or oil and definitely not rubber. I have no clue what it is.As of right now my oil pan is leaking but it happens on cold start or when it's hot, so i don't think it's oil but i could be wrong. Please reply with anything you think it might be. Thank you!
MEEPER278 is offline   Reply With Quote
Old 04-29-2020, 11:07 PM   #2
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Any oil that gets on your exhaust will smoke.
if there's a dramatically different sound that goes away after a few seconds, you have an exhaust leak, or a clogged/messed up pair valve, egr or egr delete, etc.
If there's a lot of wet leaks and the car drips, you probably need to do an intake manifold/pcv job (if that's the case, I strongly recommend pulling the motor). If you just check for suction on the valve cover breather like the manual says, you'd be golden on a car with larger simple PCV hoses, but the KA has awful tiny complex hoses and passages that need to be manually replaced/reamed, it can turn into volvo-level disaster.
No, it's not a head gasket.
mechanicalmoron is offline   Reply With Quote
Old 04-29-2020, 11:32 PM   #3
MEEPER278
Thank you for replying! There isn't any sound so i don't think it's anything in the first paragraph. The thing is though, it doesn't smell like oil burning and it even does it sometimes on a cold start so i don't think it's oil dripping onto my headers/exhaust. I also forgot to mention it smokes out of the left side of the engine bay.
Old 05-01-2020, 06:56 PM   #4
MEEPER278
Well i don't think it would be leaking on to the exhaust and burning since it happens on a cold start too. There isn't any different sound either.
