Old 05-11-2013, 07:41 PM   #3271
jamg
jamg is an unknown quantity at this point
Originally Posted by AsleepAltima View Post
20-22 pounds. Ran great for a while
7k miles aint bad for 20ish pounds.
how much power did you put down?
jamg is offline   Reply With Quote
Old 05-11-2013, 08:10 PM   #3272
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
I can only estimate but compared to other builds similar to mine, between 375 and 390.
AsleepAltima is offline   Reply With Quote
Old 05-12-2013, 12:11 AM   #3273
zombiewolf513
Originally Posted by KoukiMonsta View Post
go big, go apexi HG,
or cosworth to save a buck,
though quite often its the prep (or lack of) that leads people with cometic to fail. i had ones for years...tempted to re run it a few times now haha
I recently couldnt even find a distributor that had a coswort, since they went under.
APEXi or nothing.
IMO why the fuck would you try to save $100 with cheaper cometic as opposed to an apexi when the part is so important and hard to change.
Old 05-12-2013, 12:14 AM   #3274
jamg
I'm running a HKS racing type II bov with my 2871 setup.
hopefully it'll sound sick.
Old 05-12-2013, 07:02 AM   #3275
inopsey
inopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant futureinopsey has a brilliant future
7k miles is about 2-3 oil changes or a set of tires. a quality turbo should easily last longer than that.
inopsey is offline   Reply With Quote
Old 05-12-2013, 10:37 AM   #3276
RocketOgre
RocketOgre's Avatar
RocketOgre is an unknown quantity at this point
Cosworth was my first choice, but I did not see a stock thickness 86mm bore gasket on their website and the FRSport guys have always been good to me so I went with what they had.
Is the 87 bore 1.1thickness = stock size?
'89 hatch DD'd SR'd 2871'd - Sold
2006 Legacy GT Wagon
RocketOgre is offline   Reply With Quote
Old 05-12-2013, 10:41 AM   #3277
AsleepAltima
I agree and I bought that turbo new in the box too. I think it's because the car sat not running for the year before and after my deployment. Wide open in the engine bay because I had pulled the head before I left. The car was covered and the hood closed but it was outside for a whole winter.
Old 05-12-2013, 10:56 AM   #3278
zombiewolf513
87x1.1 is stock thickness and bore size, but you might want to call whoever youre ordering from and confirm they have the cosworth in stock. Many places do not carry them anymore since the cosworth sr head gasket line was discontinued.
Old 05-13-2013, 03:22 PM   #3279
SR20HAYES
SR20HAYES is an unknown quantity at this point
What is everyone using as far as oil restrictors go? I read many different things. Some say they use it and some say they don't. I was told I need this -3 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com. What are you guys using? Just dropped a lot of money on the new gt2871r and last thing I want to do is blow the seals or starve it.
Oh and as far as the actuator bracket goes from my previous post. It worked perfectly. here is the link again for anyone interested. Garrett Adjustable Wastegate Bracket : atpturbo.com
Again this bracket is for the gt2871r with the coupler style housing. I tried to get a picture of it installed, but it wont work for some reason.
SR20HAYES is offline   Reply With Quote
Old 05-13-2013, 03:31 PM   #3280
zombiewolf513
Circuit Sports Turbo Oil Restrictor : -3AN .030 - Enjuku Racing Parts, LLC
Old 05-13-2013, 03:37 PM   #3281
SR20HAYES
Thanks For the reply! Will the .035 be too large? Reason I'm asking is I purchased one. If so I guess I will have to buy that one.
Old 05-13-2013, 04:53 PM   #3282
zombiewolf513
I think the .035 will be just fine, but id wait for someone else to reply on that one.
Old 05-13-2013, 04:58 PM   #3283
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
OEM HG is 86x1.3 (1.3 gets smashed down to ~1.1-1.0)
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 05-13-2013, 09:43 PM   #3284
zombiewolf513
I was refering to stock bore size in terms of an mls head gasket. Apexi, cosworth, tomei; all have 87mm as the smallest bore size as far as i know.
Old 05-13-2013, 10:41 PM   #3285
derass
I am using DIF 0.032", so 0.030/0.035" will be fine. Just do not get 0.060" intended for journal bearings.
Old 05-13-2013, 10:48 PM   #3286
jamg
but his garrett is quality...
he was at 20+ psi, so that would be the reason for it's short(er) life.
Old 05-14-2013, 01:05 AM   #3287
cotbu
cotbu's Avatar
No! ,just no! It could be the reason, yes! It's just wrong to accept that! Turbo manufacturers would love, if you accepted that!
Still doesn't make what you said here correct, The mls hg 87mm standard, follows the rule of being, 1-2mm bigger etc, but you can use a direct bore size no problem. So if you are 86-87mm you could use the 87mm bore and not have to get an 88mm
The cosworth gaskets can still be found, you just have too look and expect to pay $30 more on avg for them, as my research shows.
The recommended restrictor size for ball bearing turbos is .035. If you go smaller,or bigger, base it on oil pressure and type of oil.
Old 05-14-2013, 01:43 AM   #3288
jamg
what do you think could be the cause of a short turbo life?
Old 05-14-2013, 02:02 AM   #3289
cotbu
cotbu's Avatar
I really don't know for sure, but being as he said the crha came apart. That could be a manufacturing issue, but he also said he left it outside to the elements. That's an end user issue. Maybe oiling, or cooling?
Just a fluke maybe, I would still send it back to the manufacturer, and see what they say.
What I was saying is that, there is noway I would accept paying $1100+ on a turbo and only expect it to last 7k miles, you shouldn't either.
Old 05-14-2013, 05:24 AM   #3290
KA240SX808
KA240SX808's Avatar
Nope.
Apexi, HKS, etc. All come in 86mm bore sizes also.
Old 05-14-2013, 08:10 AM   #3291
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Apexi lists 86mm bore (as that's what I have on my engine and others) but it's not an exact 86mm bore, it's really for an 86.5. 1.1 is the thickness I always run too.
In regard to a turbo not lasting, it can be a plethora of things. Oil feed, oil type, air filter type, and or whatever else that can ingest itself and spit out the exhaust (spark plug tips)
Don't get me wrong, I'm a huge Garrett fanboy, but any company can have defects in things and most take care of you in that event. My personal car had 30k on the 2871r and it's still in great shape when I changed over to the GTX2867. I know of countless other 30-50-70k Garrett turbo users as well, on cars that get abused.
Old 05-14-2013, 02:46 PM   #3292
RocketOgre
RocketOgre's Avatar
That is it right there, we can drop this argument now. 1 year unprotected from the elements will kill most metal things, fragile metal components in a turbo are done for.
Old 05-14-2013, 04:10 PM   #3293
AsleepAltima
and thats what i myself am blaming. i dont doubt garretts quality, its me leaving it outside because of deployment and surgery that i blame. theres no way that any reputable turbine company is going to build a sub 10k mile turbo. hell, the little tiny turbo on my evo pushes out 20lbs all day and theres dudes running them much higher. i seriously doubt that 20-22 lbs was killing that turbo.
Old 05-14-2013, 05:42 PM   #3294
tabasco122
tabasco122 is an unknown quantity at this point
he said it was in his engine bay with the hood closed and a cover on it, by those standards everyone's turbos are in the elements...
tabasco122 is offline   Reply With Quote
Old 05-15-2013, 09:40 AM   #3295
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Well, I installed my JWT S3 cams last night. Went well. The idle is now more lopey than I was expecting, haha I guess I hadn't thought about it.
But I haven't really smashed into the throttle yet, just checking for low throttle AFR and making sure the tune is still safe and clean. Anything I should do before going out and pounding on it?
And the power increase I should be able to feel...right? Like butt dyno? Haha
What is the usual horsepower increase from installing S3 cams on an otherwise very clean solid running car?
-Kyle
BlackZenkiS14 is online now   Reply With Quote
Old 05-15-2013, 11:37 AM   #3296
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Although i havent done it yet myself. To maximize the actual gains youll probably want to retune for the cams powerband. And it may not give you instant results like you expect
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 05-15-2013, 11:40 AM   #3297
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Slap some Tomei cam gears on there then go get a tune. Your butt dyno will shit itself lol
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 05-15-2013, 11:47 AM   #3298
zombiewolf513
Noticable. Better with a tune
Old 05-15-2013, 01:12 PM   #3299
BlackZenkiS14
Im running a JWT ECU, so I wont need a retune. I'll be keeping an eye on my AFR's though to make sure it stays nice and tidy at 11.7ish.
-Kyle
Old 05-15-2013, 01:42 PM   #3300
ultimateirving
Oh ok. So when you ordered the tune you said I have s3 cams waiting to go in? And had the tune designed around it ?
Z32 with lq4 swap
