Old 10-14-2009, 02:16 PM   #1
Sileighty_DRFT89
Sileighty_DRFT89's Avatar
Sileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfectionSileighty_DRFT89 is close to perfection
smog issues with stock ka24de
I recently got reffed and I need my car to pass emissions (modified smog ticket). when I got it tested at the reff yesterday it had failed on HC's and CO's. I've changed the cat, changed plugs, checked timing (good), cleaned egr, replaced 02. I was wondering if anyone has any other solutions to get these to pass on a good number as the reff is really strict. I need some pointers to get the car to pass or I won't be able to drive it on the street any longer . any help would be appreciated. thanks in advance
Sileighty_DRFT89 is offline   Reply With Quote
Old 10-14-2009, 06:30 PM   #2
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
http://zilvia.net/f/tech-talk/92533-...-high-nox.html
I know it says nox, but it has other helpful advice for passing smog.
Did you heat up the cat a lot? Maybe the EGR is bad?
Old 10-14-2009, 10:57 PM   #3
Sileighty_DRFT89
egr is good. I bansai'd it for a 20 minute drive to the reff at like 5000 lol. I think it was warm enough. thanks for that thread man
Old 10-15-2009, 03:53 AM   #4
blackrms13
blackrms13's Avatar
blackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfectionblackrms13 is close to perfection
Send a message via AIM to blackrms13
get an oversized cat...it helps
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 10-15-2009, 08:14 PM   #5
rioredstang
rioredstang's Avatar
rioredstang is an unknown quantity at this point
failed emisions
if the HC & CO are both high then it is running rich. you need to look at the o2 sensor reading and make sure it is switching. Should switch between .100mv to .800mv. You can use a volt ohm meter to watch the reading. Make sure Mass Air Flow Meter is clean. Make sure there are no vacuum leaks between maf and throttle body. Retarding the timing will lower HC levels. Changing the oil can help a little. I don't know what the levels were to give any more advice.
rioredstang is offline   Reply With Quote
Old 10-17-2009, 12:04 PM   #6
Sileighty_DRFT89
so I've found another issue. my car is an 89 so it should origanally have a single cam. my car came with a dual cam. so the reff said my timing has been set at 15* or should be because they were looking in the 89 service manual which would show the timing of a single cam. the guy that had timed my car must of thought it was a single cam too as it was set at 15*. also the reff had said that the timing was supposed to be set at this. If I tell the reff that the motor has been swapped would I have to get it bar'd?? since its not the motor that originally came in my car?? how would this work??
Old 11-11-2009, 11:19 AM   #7
tofast4u05
tofast4u05 is an unknown quantity at this point
You shouldn't have to get the car bard because the motor that is in it originally is from a 240sx. It's just out of a newer 240sx which should be OK to swap as long as it passes smog.
tofast4u05 is offline   Reply With Quote
