08-24-2005, 09:14 PM | #31 |
Sounds more like driving style/front tires. Possibly camber settings up front. Have any pictures of your drifting? Your camber and caster should be set together with your tire size so that you have full contact patch on your loaded tire at full lock. You can also check your tire wear. Where is i most worn?
08-25-2005, 10:38 AM | #32 |
From Whiteline:
Touring: Front: Camber: -1.5 deg Caster: L+7.5/R+7.0 deg Toe: 0.0mm Rear: Camber: -1.0 deg Caster: n/a Toe: 1mm in Sport: Front: Camber: -2.0 deg Caster: L+7.5/R+7.0 deg Toe: 0.0mm Rear: Camber: -1.25 deg Caster: n/a Toe: 0.5mm in Factory: Front: Camber: -1.50 to 0.0 deg (-0.75 deg nominal) Caster: 6.00 - 7.50 deg (6.75 deg nominal) Toe: 1.5 - 3.5 mm in, (2.5 mm in nominal) Rear: Camber: -1.67 to -0.67 deg (-1.17 deg nominal) Caster: not adjustable Toe: 0.0 - 5.0 mm in, (2.5 mm in nominal)
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
