Old 10-15-2011, 07:02 PM   #1
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
STI 560cc top feed injectors w/ rings
For sale is a set of top feed 560cc dark blue STI injectors with new o-rings. I got these to use on my SR20DET but never installed them. $ SOLD
Trades considered for a variety of things: oil cooler setup, NRG quick release or momo short hub, isis intake manifold, like new black floor mats or carpet, powdercoated valve cover, aluminum water overflow tank, projector headlight setup, bride low passenger seat rails, Stance oversize water pump pulley, or ?
Seraphim38 is offline   Reply With Quote
Old 10-31-2011, 10:36 AM   #2
infinitedrift
infinitedrift is an unknown quantity at this point
I would have to buy the pig tail for it right and splice it up?
infinitedrift is offline   Reply With Quote
Old 10-31-2011, 10:46 AM   #3
Seraphim38
Seraphim38's Avatar
the point with using STI injectors is that plug is identical other than the rib shown on the side of the plug. If you grind that rib down, the stock SR20 wiring harness plugs in. That's one of the main reasons why they are so commonly used in SRs.
I had STI 550cc side feeds on my SR up until this last weekend, and they were plugged into the stock injector plugs.
Secondly, Enthalpy and other tuners will tell you that the spray pattern and ability to tune STI injectors are far better than the old fatty MSD top feeds (less idle richness problems and more).
For practical purposes, the STI top feed 550s are also better than side feeds for several reasons, which is why big setups always run top feeds.
Old 10-31-2011, 11:30 AM   #4
infinitedrift
ill would be running this on a ka-t setup, is it the same plug and play wire harness besides the rib?
Old 10-31-2011, 12:59 PM   #5
Seraphim38
Seraphim38's Avatar
That I am not sure about, as my 240SX already had an SR20 swap when I bought it. My guess is that they are the same, but I can't personally say for sure.
I probably could take a close up photo of the injector plug if you can take a look at your harness.
Old 10-31-2011, 01:00 PM   #6
spartanmisfit
spartanmisfit's Avatar
Trader Rating: (18)
spartanmisfit is an unknown quantity at this point
Feedback Score: 18 reviews
Its the same thing with a ka. I had the yellow 550s in my ka
spartanmisfit is offline   Reply With Quote
Old 10-31-2011, 01:44 PM   #7
infinitedrift
That would Be great if you could.
Old 10-31-2011, 10:16 PM   #8
infinitedrift
payment sent!
Old 11-01-2011, 08:34 AM   #9
TriniGT
TriniGT's Avatar
TriniGT is making a name for him/her selfTriniGT is making a name for him/her self
Let me know if it falls through as I am interested in them.
TriniGT is offline   Reply With Quote
Old 11-01-2011, 12:29 PM   #10
Seraphim38
Seraphim38's Avatar
Injectors sold to infinitedrift
