Old 12-16-2008, 02:39 PM   #1
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
s13 water in trunk, hatch. wtf
so last night it was raining so i took my subwoofer out of my hatch, put in a towel cause it was damn, and this morning the towel was soaked. my amp looked like there was dew on it, the whole back was wet, behind the tail lights there was dew, and on the right coilover tower it was wet.
what i need to know is is there a hole or some thing, the seals seem to be good. but where is the water coming from?
handinpants is offline   Reply With Quote
Old 12-16-2008, 02:51 PM   #2
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
we you pull your trunk leaver does it pop open?
if no then the latch is too high and yyou need to lower it
a few MM so it can seal it self tightly
also check the weather sealant around the rear hatch lights
it might need replacement due to age
it's called butyl they sell it at auto parts stores
<3
-los
los_inc is offline   Reply With Quote
Old 12-16-2008, 03:06 PM   #3
g6civcx
g6civcx's Avatar
g6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfectiong6civcx is close to perfection
Taillights, antenna, wire harness grommets for the defroster, brake lights, and wiper, hatch moulding.
Good luck.
g6civcx is offline   Reply With Quote
Old 12-16-2008, 03:11 PM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Almost certainly the hatch seal. That is the most common shit ever on fastbacks. Occasionally the tail lights will leak too, but not as common. I have not heard of the antenna hole leaking before.
racepar1 is offline   Reply With Quote
Old 12-16-2008, 03:15 PM   #5
g6civcx
g6civcx's Avatar
The antenna is designed to leak. There is a drain hose from where the antenna mounts to the fender to the inside of fender and onto the ground.
If the drain hose is clogged or becomes damaged otherwise, the antenna rod will drip into the interior.
http://zilvia.net/f/s-chassis/229868...ml#post2512371
Originally Posted by Russ
99% of trunk leakage is from the tailights, the butyl rubber sealant dries out and becomes brittle, allowing for water to leak through, especially if the tails have ever been removed.
You guys work it out.
Old 12-16-2008, 03:20 PM   #6
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
Same with me. I had to dig all the water out of my trunk with a bucket because the spare tire area was half filled with water. I looked at the weather stripping on the hatch and it was torn about 3" on the passenger side and saw some rust leaks from the taillight. Sucks.
w0nderbr3ad is offline   Reply With Quote
Old 12-16-2008, 03:27 PM   #7
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
Go to sears or something and get boat sealant. Its a toothpase like thing of black goo you can use to seal stuff. If its the tailights, antenna, etc stuff like that you can goo the edges and re-seal it. I had to re-seat my tailights on my old subaru after I was rear-ended and it took all of like 45 minutes and it stopped the water.
renegade_ewok is offline   Reply With Quote
Old 12-16-2008, 05:38 PM   #8
alzahakar
alzahakar's Avatar
alzahakar has a little shameless behavior in the past
Same problem here. Mine's the tail lights. Also, I've only ever owned a S14 and S13 coupe, so I don't know about the S13 fastback, but my buddy's Z31 had some drainage holes between the rear quarter panel and the hatch seal that were clogged and it caused the water to back up and drain into the hatch anyway. If S13s have the same type of holes, maybe that's a possible cause.
alzahakar is offline   Reply With Quote
Old 12-17-2008, 06:40 AM   #9
soldiaboy
soldiaboy is an unknown quantity at this point
me 2. at first I thought it was a fkn prank
ill look into this too thanks
soldiaboy is offline   Reply With Quote
Old 12-17-2008, 10:43 AM   #10
racepar1
racepar1's Avatar
You guys know that there are plugs at the bottom of the spare tire well that you CAN remove to drain the water right? Hell when it rains I just take them out automatically.
Old 12-17-2008, 10:55 AM   #11
g6civcx
g6civcx's Avatar
The water runs through the threaded nut portion of the antenna base, down the drain tube, and out of the car via a little drain hole in the inner fender.
If the the tube is broken or clogged, water will drip into the interior and possibly run along the interior panels onto the spare tyre area depending on where the breakage is.
Old 12-17-2008, 11:41 AM   #12
BlckBeautyVTEC
BlckBeautyVTEC's Avatar
BlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really niceBlckBeautyVTEC is just really nice
Send a message via AIM to BlckBeautyVTEC
that shit is always out in my car
poop mama...
BlckBeautyVTEC is offline   Reply With Quote
Old 12-23-2008, 04:06 AM   #13
handinpants
FreshColdBeer.com
Trader Rating: (48)
it seems to get wet behind the rear tire area and ontop of my coil over... wtf is there a hole i can't see?
Old 12-23-2008, 05:44 PM   #14
soldiaboy
yes I know that, but it doesnt solve my problem
Old 12-24-2008, 05:18 PM   #15
reinvent
reinvent is an unknown quantity at this point
carbon monoxide is good for you.
reinvent is offline   Reply With Quote
Old 12-24-2008, 05:19 PM   #16
reinvent
leaking hatches is one of the most frequent topics. google it.
Old 12-27-2008, 10:50 AM   #17
g-via
hatch seal hatch seal hatch seal and grommet for wiring near the hinge
g-via is offline   Reply With Quote
