Old 11-04-2009, 12:55 AM   #1
89s13silvia
89s13silvia is an unknown quantity at this point
s14 coilovers on s13 w/ skyline alluminum knuckles?
Hey guys I'm building a track silvia and I figured a way to cut down a bit of weight is using s14 coilovers (as the fronts fit already) and rears and fitting them up to skyline alluminum knuckles w/ the tapered steel ball ball joints. I am just wondering if this will work. I know I would need to use the lower control arms from the skyline but would this even work? I assume there would not be much difference between heights of the s13 to s14 by switching over rears or am I wrong?
89s13silvia is offline   Reply With Quote
Old 11-04-2009, 01:01 AM   #2
zenki.life
zenki.life's Avatar
zenki.life is an unknown quantity at this point
Send a message via AIM to zenki.life
no. have you seen the the height difference between the two.
FAIL.
just buy the right coils for your car.
end thread
Originally Posted by super240s14 View Post
man you all are ass holes...... and that is rude to talk like that on zilvia im reporting all you...... ZILVIA ADMINISTRATION PLEASE BANNED ALL THREE OF THESE DUDES
^^another person learns the perils of "stupid posting" on zilvia, too bad none will care.
zenki.life is offline   Reply With Quote
Old 11-04-2009, 01:48 AM   #3
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
thank you...couldnt have said it better myself
negrosx13 is offline   Reply With Quote
Old 11-04-2009, 06:57 AM   #4
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
what you need to do is search. its been covered already. Use z32 rear knuckes (alum) and correct tapered balljoint (IIRC Q-45 has what u need). then u need a lower mount. you can eithor get z-32 rear coils, with s-13 upper mounts. OR get/mondify lower mount on coil-over to fit knuckle.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
