Old 02-22-2015, 04:38 PM   #1
jdmdrifter18
jdmdrifter18 is an unknown quantity at this point
after ka24de swap injectors not firing
So I'm having this problem where my injectors aren't firing whatsoever the injectors dot even have pulse. I get spark, I double checked the lines and they are put on correctly and fuel comes from the feed line. It just seem like the aren't firing at all. The timing is abit off but I don't think that would cause them to not fire.btw I'm doing a dual cam swap into a 90 chassis. Also another wierd thing is that when I check the ground on the ground infront it shows there's a closed circuit even when the ground is not bolted into the block...?
jdmdrifter18 is offline   Reply With Quote
Old 02-26-2015, 10:56 PM   #2
adversedroyd
adversedroyd is an unknown quantity at this point
Double check all wiring and that grounds are properly grounded. For me it was that when I did my swap. If fuel comes out of the fule rail on the return line when you disconnect it, then you might have bad or clogged injectors. Assuming you get spark.
adversedroyd is offline   Reply With Quote
240sx, ecu electrical, injectors
