![]() Okay I will try to make this quick. We are trying to wire my buddies car and am so lost. We have gotten down to the ecu relay and are confused. The write up says that the ecu relay should have two red wires, a black/white, and a red/black. Our ecu relay as a green, green/white, black, and pink. Please help us figure this out because we cant get it to start and think that this might be causing it. Thanks |
![]() Join Date: Dec 2003
I have some literature on this swap and have done this harness three or four times. Unfortunately I don't have any of my notes with me at work. If you want give me a shout later tonight and I can look through it for you.
that is unless some answers you sooner.
![]() file:///C:/Documents%20and%20Setting...14_sr20det.pdf
This should help It works for a s13 and s14. Wiring should be in the 600pgs. |
