Old 05-28-2009, 03:23 AM   #1
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
someone please ID this harness
its a grey 4 pin harness that is located underneath the pass side fuse box. it looks like it should plug into the lower engine harness but i have no plug that fits.
im currently doing a dohc to sohc swap, and without this plug in place the car doesnt even crank or click.
im using a sohc engine harness and a sohc lower harness. i dont have time to find a dohc lower harness, so does anyone know what this 4 pinner does?
supreme_1 is offline   Reply With Quote
Old 05-28-2009, 04:15 AM   #2
supreme_1
okay, so i was doing some research and comparing a bunch of wiring diagrams i wrote down. heres what i found.
the body harness tucked away behind the battery in the pass fender has these 4 wires tucked away in there. (car was originally 1991 dohc)
yellow with blue stripe
red with blue stripe
black
2 brown wires
one of those brown wires are for the 02 power signal and the other is the wire i need to tap into.
in my sr diagram these wires are just chillin on the side with no home, so im guessing they are only specific to sohcs/dohcs, the dohc wiring that i had looked at does not have the red/blue, black, and one brown in it, so im guessing thats sohc specific.
can someone please chime in to make sure my rationale is correct. the last thing i need is to fry something right before we finish.
lastly, does anyone know exactly what these wires are?
yellow/blue
red/blue
black
brown
Old 05-28-2009, 12:27 PM   #3
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
Almost looks like the A/c fan plug ??
WoolyS14DET is offline   Reply With Quote
