Old 10-14-2012, 03:36 PM   #1
justin_bfn
justin_bfn's Avatar
justin_bfn is an unknown quantity at this point
rb20det tranny issues
So this just started doing this the other day. My reverse is gone it just grinds. its incredibly hard to get it in first and fourth grinds at high rpm. There has been a hum when i'm rolling down the road so i just have assumed it was something with the drive shaft because i was having drive shaft issues when i bought the car. I've heard things from bad or low gear oil to my clutch to my t/o bearing to even theres not enough travel for my slave cylinder. Can someone help? This car has been nickel and diming me like none other.
justin_bfn is offline   Reply With Quote
Old 10-16-2012, 07:39 AM   #2
sandor
sandor is an unknown quantity at this point
I put some GM synchromesh in my SR tranny and it helped a bunch. If you don't have air in your clutch line or a bad slave cylinder, then I'd suspect your transmission is in trouble.
sandor is offline   Reply With Quote
Old 10-16-2012, 09:10 AM   #3
Sileighty_85
Sileighty_85's Avatar
If adjusting the clutch pedal doesn't help and its only in reverse then the syncros are fucked.
Just Find a KA tranny and swap bellhousings
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
rb20 s13, rb20det, s13 240sx, s13 coupe, transmission
