Old 03-14-2006, 12:07 AM   #1
240sxworkinprogress
240sxworkinprogress's Avatar
240sxworkinprogress is a well-known jackass
s14 Strut rub under hard cornering
Yess I checked and searched.I found nothing that relates to what I'm asking!! What I was wondering is that I'm about to buy a set of BF Goodrich Sports 225/50/16 tires for my 16x7 rims witch are going on my 95 240. I have a Sr going in and I want the addictional traction. I know that they will clear the rear struts but what about the front. I don't want them to rub under hard cornering. I'm using them for autocrossing to. I was told that then would fit but before I spend 300 dollars for tires I want to make sure!!!!
240sxworkinprogress is offline   Reply With Quote
Old 03-14-2006, 01:19 AM   #2
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
Cant give you an answer without listing the wheel offset.
Nizzan4u2nv is offline   Reply With Quote
Old 03-14-2006, 02:27 AM   #3
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
You can always run a small 10mm sandwhich spacer in the fronts for like 15 bucks if wheel offset is too high.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 03-14-2006, 09:22 PM   #4
240sxworkinprogress
Yea sorry I'm running a set of motegi Mr7 with agx struts. I don't know what the offset would be.
