Old 09-17-2015, 07:49 AM   #1
splitfire
splitfire is an unknown quantity at this point
Crank & rod bearings wear
Greetings.
Can someone advise me in regard to wearout of these bearings?
Common sight:
Bearings of 1-4 cylinders, left to right:
Why are there worn areas near the edges of bearings?
This scratch on the rod bearing of 4th cylinder can be felt by fingernail.
Can I leave these bearings or I should replace them?
splitfire is offline   Reply With Quote
Old 09-17-2015, 08:33 AM   #2
Croustibat
Croustibat is an unknown quantity at this point
I'd say worn more on the sides means crank walk, not enough oil pressure, and/or crank journals with uneven surface. Can't say much more tbh.
Croustibat is offline   Reply With Quote
