Old 08-20-2010, 01:44 PM   #1
Datenshi
Datenshi is an unknown quantity at this point
S13 Digital HUD Cluster
Alright, so I have a 89 hatch and got a complete dash and an s13 hud cluster from a coupe. Has anyone on here installed the cluster into a hatch? I've found some guides on how to do it.. I just want to make sure it works from people who've done it before I start ripping my dash and cluster out.. to find out it doesn't work well, or at all. My idea is just remove my current hatch dash and cluster, and replace it with the s13 dash and cluster.. should be just plug and play no? I've got the wiring harness, the windshield display unit thing.. and the digital cluster.
Any advice is appreciated, thanks ahead of time.
Datenshi is offline   Reply With Quote
Old 08-20-2010, 01:48 PM   #2
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
you can always located the main harness to from your old cluster and plug all the necessary harness for the HUD cluster before ripping it apart.
theres an DIY here or nico i stroll through awhile ago.
Sam_Well.13 is offline   Reply With Quote
Old 08-20-2010, 01:49 PM   #3
niteridaz503
niteridaz503's Avatar
niteridaz503 is an unknown quantity at this point
If you have the HUD dash, projector, cluster and wire harness then you are fine its just plug and play. I did a digital cluster but without the projector & HUD dash without any issues as long as you have the harness.
Originally Posted by yetijeff View Post
Hes higher than giraffe pussy lolz
niteridaz503 is offline   Reply With Quote
Old 08-20-2010, 01:52 PM   #4
Sam_Well.13
here. theres picture in here that might help you with you question
analog to digital cluster help - Nissan 240SX Forums
Old 08-20-2010, 01:52 PM   #5
Datenshi
Alright sick, thanks guys lol. Didn't wanna go thru the hassle without any reward. :P
I saw the DIY's and stuff on NICO, was just making sure that they were infact a working DIY lol.
Old 08-20-2010, 01:58 PM   #6
Datenshi
So I might have to replace my tach? I have the SOHC KA, I'll have to check when I get home.. but I'm pretty sure the tach is for a DOHC.. will it matter? They say just to swap tach for tach, is it true?
Old 08-20-2010, 02:15 PM   #7
niteridaz503
should work for both honestly because most digital clusters came in single cam cars but dont quote me on that because my buddies car was a single cam originally & it worked & mine is a twin cam & it works too.
Old 08-20-2010, 02:22 PM   #8
sleeper108
sleeper108 is an unknown quantity at this point
I was under the impression that a SOHC tach will read a DOHC engine's revs twice as fast as it should, and I assume the opposite is true of a SOCH with a DOHC tach. (rev half as much as it should)
I would replace them just to be safe, but I am known for being horrible with wiring and electronics, so don't quote me! lol
sleeper108 is offline   Reply With Quote
Old 08-20-2010, 02:55 PM   #9
Datenshi
^ Lol, me too.. which is why I asked here to begin with.
I've got both tach's so it won't matter.. and I don't really care what it's redline says.. I'm not a noob. So, I guess I'll leave it.. plug it in and try it.. then switch it otherwise if it doesn't work properly.. thanks for all the help guys.
Old 08-20-2010, 03:07 PM   #10
niteridaz503
no prob like i said its usually plug & play only either way just keep us posted & ill help as best i can
Old 08-23-2010, 10:12 AM   #11
tommytwo40hands
tommytwo40hands is an unknown quantity at this point
correction, digital hud clusters only came in 89-90 coupes. it was a factory option package (power convenience group)
tommytwo40hands is offline   Reply With Quote
Old 08-23-2010, 10:42 AM   #12
Datenshi
I didn't get a chance to dig the digital hud out to check the redline on the tach, but if your right.. then the tach should match my car perfectly? I drive an 89 hatch. I shouldn't have to swap the tachs then?
Old 08-23-2010, 01:04 PM   #13
tommytwo40hands
not unless you've swapped in a DE or SR, both the motors are sohc so the tach should match up perfectly..the HUD only controls the speedometer..as for the dash they're both s13 so they should fit perfectly, the only difference is that one has a trunk and one has a hatch.
Old 08-23-2010, 01:55 PM   #14
WheelWhore
WheelWhore's Avatar
WheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymoreWheelWhore is not welcome here anymore
Where the fuck you getting your info?
I have pulled out DOHC Digi tachs from 91-93 Coupes.
Matter of fact I have swapped them in Hatches too.
OP:
This is what you need:
Projector and Cover
HUD Cluster
HUD Subharness
Unbolt the Steering Column Cover
Unbolt upper and Lower Steering Column
Remove screws from Cluster Bezel
Unplug Buttons
Remove Bezel
Remove Cluster
Cut Ziptie Holding in Analog Subharness
Remove Subharness
Plug in HUD Subharness
and reverse the rest of the steps.
Of course if you do not have a HUD dash, you can cut out that portion. While I have never gone this route, it is said the template it on the underside.
IDK if the Cluster Bezels between Analog and Digital are the same, but my Digi Cluster always fit REALLY snug with the analog bezel.
STOP SPREADING MIS INFO.
DOHC Digi in my old '94 Hatch.
WheelWhore is offline   Reply With Quote
Old 08-23-2010, 02:09 PM   #15
stinky_180
stinky_180's Avatar
Trader Rating: (26)
stinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud ofstinky_180 has much to be proud of
Feedback Score: 26 reviews
Send a message via AIM to stinky_180
Its plug and play... be sure to have the subharness for the digital cluster.
SoCal RallyX Coverage and MTB Ride Reports
WheelsDirty
stinky_180 is offline   Reply With Quote
Old 08-23-2010, 02:10 PM   #16
niteridaz503
thankz for the clarification WheelWhore cuz i thought i was wrong there lol
Old 08-23-2010, 03:06 PM   #17
Datenshi
Yeah, I knew everything 'should' fit, just wanted to verify with people who know 100%. Nothing gayer then ripping apart the car to find out you wasted your time and it doesn't fit.
And thanks again everyone for the solid info.
Old 08-23-2010, 03:56 PM   #18
WheelWhore
WheelWhore's Avatar
hey no problem man. lmk if you have any questions. shouldnt take you more then a hr MAYBE a hr and a half for someone not completely fluent with removing the cluster.
Goodluck.
