Old 08-01-2013, 09:49 AM   #1
m_240sx
m_240sx is an unknown quantity at this point
Front driver side rumble/clunk sound
So Tuesday I was driving to work. I hit a little bump in the road and I heard my front end make a pop sound. I stoped at the next stop light and at idle my car started making a clunking noise and a lille popping sound when I turned (left) so I pulled into a parking lot got out looked under my car and saw this (see attached photo. So that evening replaced the tie rod and boot. The noise isn't as bad now but its still there a little bit.. what else could it be? I greased the boot up very good. Do u guys think maybe it just needs to be driven a little to relubricate or something else?
For everyone information its a 92 240sx coupe lowered on Megan coilovers.
Sent from my HTC Droid DNA using Tapatalk 2
m_240sx is offline   Reply With Quote
Old 08-01-2013, 09:53 AM   #2
fast250sx
fast250sx is an unknown quantity at this point
Check ur wheel bearing
fast250sx is offline   Reply With Quote
Old 08-01-2013, 10:08 AM   #3
m_240sx
Ill try to check when I get home tonight.
Also I can feel it in my steering wheel.
Old 08-01-2013, 11:53 AM   #4
Mikester
Mikester's Avatar
Mikester is a well-known jackass
CHeck your ball joint too... and make sure the caliper is on good & tight.
Mikester is offline   Reply With Quote
Old 08-01-2013, 01:57 PM   #5
m_240sx
When checking the ball joint what should I look for to let me know if its ok or not.
Old 08-01-2013, 02:00 PM   #6
jabless13
jabless13's Avatar
jabless13 is an unknown quantity at this point
Grab the wheel and shake it left and right and have someone else look for the ball joint to move. Also shake it at diagonal angles. Sometimes a ball joint will only have play a certain direction.
jabless13 is offline   Reply With Quote
Old 08-01-2013, 02:20 PM   #7
m_240sx
Gotcha. Thank you for the tip. Ill try this to Ight if I get time Thx again.
Old 08-01-2013, 02:45 PM   #8
Mikester
Mikester's Avatar
^^Grab the wheel at the top and bottom and try to wiggle it in/out... If it wiggles and is pivoting on the ball joint; it's toast.
