Old 07-21-2004, 10:05 PM   #1
HATchTRICK
HATchTRICK's Avatar
HATchTRICK is an unknown quantity at this point
Intake pipe's on SR20det
What are you guys using for the replacement of that stupid ass rubber bendable pipe? (some kinda aftermarket intake form another car cut apart?)
I have been having boost fall off around 15-16 psi and i read somewhere that the rubber intake pipe is capable to crush around 15 lbs of boost. IS THIS TRUE?
If this is true it might be my problem of the boost dropping when it hits 15 psi(drops back down to 12-13 lbs) ( choking the turbo of air)????
HATchTRICK is offline   Reply With Quote
Old 07-21-2004, 10:11 PM   #2
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Maybe if you have a dirty filter it will cave in. I highly dought it will crush with an open element.
TheSnail is offline   Reply With Quote
Old 07-22-2004, 02:39 AM   #3
Andrew Bohan
yeah you'd need WAY more than 16 psi to do that
anyway, you can get metal pipes as part of a kit, or you can have one made.
or you can search and find the discussion that was had not too long ago
Old 07-22-2004, 10:22 AM   #4
Mr. Badlose
Mr. Badlose is an unknown quantity at this point
Send a message via AIM to Mr. Badlose
http://www.zilvia.net/f/showthread.p...rd+intake+pipe
Mr. Badlose is offline   Reply With Quote
Old 07-22-2004, 10:47 AM   #5
silvarshootin
silvarshootin is an unknown quantity at this point
When i got my motor it had the cold pipe from a blitz intercooler hanging off of it, so i rigged an intake out of that, it looks way better and is much larger diameter than the stock rubber intake.
silvarshootin is offline   Reply With Quote
Old 07-22-2004, 03:02 PM   #6
HATchTRICK
HATchTRICK's Avatar
I got that crushing intake tube idea from a BLITZ turbo kit write up. I wasnt making it up. It sounded like a reasonable solution to my problem... Maybe my MAFS isnt allowing enough air through it..... i con't figure it out though.
Old 07-22-2004, 03:26 PM   #7
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
projectsilvia.com carries the Cusco hard intake pipe. check it out
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 07-23-2004, 10:20 AM   #8
Mr. Badlose
Ah. The literature about it is kind of scary, but it looks right. Nice.
