Old 06-06-2004, 11:35 PM   #1
Pudula
Pudula is on a distinguished road
Send a message via AIM to Pudula
Oil pressure problems (cont)
So i just took my oil pan off and drained my oil, etc. The capacity of oil with filter in the engine is 3 1/4 quarts according to the fsm (also says 3.7 liters, which equals 3.9 quarts). I had 5 1/4 quarts in the engine. How could that much oil affect the engine and how it runs? also, what is the REAL capacity of the SR (s14) engine oil?
Thanks, Ryan
Pudula is offline   Reply With Quote
Old 06-06-2004, 11:51 PM   #2
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
Too much oil can lead to the crank and rods whipping it up and adding air -- not good
Just fill until the dip stick says "F"
Kid Zelda is offline   Reply With Quote
Old 03-17-2005, 07:28 PM   #3
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
does anyone else have anything to add to this? i filled up my SR with 5 quarts of Royal Purple 15W40, and it's just a little over the FULL mark. I figured since i only drive the car on the track it wouldnt hurt to have some extra oil in there... ?
Hi
Var is offline   Reply With Quote
Old 03-17-2005, 09:46 PM   #4
silvarshootin
silvarshootin is an unknown quantity at this point
i only put about 3.5 quarts of royal purple in my s14 sr and it is always at or just below the full line.
silvarshootin is offline   Reply With Quote
Old 03-17-2005, 10:30 PM   #5
Var
Var's Avatar
question is about oil pressure... if the engine is always spinning at close to redline, will the extra oil hurt or help?
Hi
Old 03-18-2005, 12:52 PM   #6
noodl35
noodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura aboutnoodl35 has a spectacular aura about
Send a message via AIM to noodl35
just got my sr started up, i had no oil pressure before so i replaced the head with a cleaned one, pushed air thru all the oil holes in the block, replaced oil jet by timing chain. I'm getting oil pressure now. Since ih ave a greddy pan i just put 5 1/2 quarts
noodl35 is offline   Reply With Quote
Old 03-18-2005, 01:09 PM   #7
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
most oil pump/sump assemblies need a vent, if oil level is too high, like Kid said ull end up frothing oil one way or another. oil temps rise... and windage on bottom end makes car feel crappy.
ive personnally seen this on my brother in laws car>> in the end u can have oil pump outta ur dipstick hole (his came outta there, but im sure it can come outta diff places.) and catch fire, lol, hes so traumafied now, he goes to jiffy lube , lol
this is prolly for tech but... oil control is the name of the game, exceeding oil capacity and vents wont be vents and oild control will be sucking,
ultraDorksGarage is offline   Reply With Quote
Old 03-18-2005, 01:15 PM   #8
Yoshi
Yoshi's Avatar
Yoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to beholdYoshi is a splendid one to behold
Glad I wasn't alone in the oil capacity... I have a redtop, and I'm at the upper limit if I put in 3.5quarts.
What is the capacity difference between S13 and S14 SRs?
www.360realms.com/S13-S15
Yoshi is offline   Reply With Quote
Old 03-18-2005, 01:20 PM   #9
ultraDorksGarage
dunno bout differences, but if u wanna add oil capacity without a pan, u can try big stainless braid lines remote oil filter and low restriction oil cooler, my oil capacity is 5.75 quarts now(very little oil pressure drop was found with use of hp1 filter on relocator
On a side note Torco mpz isnt getting any cheaper, im gotta sell a kidney to pay for lube soon.
