Old 05-03-2008, 04:02 PM   #1
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
WTF? BRIDE seats hitting door pocket!!!
So im doing my BRIDE ERGO and noticed the seat was to close to the door and a considerable gap between the center console and seat ? seems like im gonna have to remove the the door pockets so they can close ? Do im doing something wrong ?
im using bride rails MO N049 and N050
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 05-03-2008, 04:10 PM   #2
boozels
boozels's Avatar
boozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to allboozels is a name known to all
it happens sometimes
seat rails do not always line up correctly
try and mess around with the mounting points
on mine i had to cut off the tabs and re weld them in to make the seat align correctly
t-apc.com t-apc.com t-apc.com t-apc.com
boozels is offline   Reply With Quote
Old 05-03-2008, 04:42 PM   #3
ROIDMONKEY
ROIDMONKEY's Avatar
figured out . i used the big brackets that came with rails and done. they sit perfectly now.
