Old 07-31-2008, 12:14 PM   #1
JDM_eightSIX
JDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to allJDM_eightSIX is a name known to all
What are these plugs?
I am trying to figure out what these 2 plugs are for. Both of them go to the Driver side fuse box. I want to say they were for the AC but not 100% sure. Also trying to figure out what that plug is for on that bracket?
JDM_eightSIX is offline   Reply With Quote
Old 07-31-2008, 12:43 PM   #2
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
UNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond reputeUNISA JECS has a reputation beyond repute
Feedback Score: 40 reviews
Send a message via AIM to UNISA JECS
The plug with the metal clip is the PAIRC-Solenoid valve I believe
UNISA JECS is offline   Reply With Quote
Old 07-31-2008, 05:23 PM   #3
JDM_eightSIX
Anyone else?
Old 07-31-2008, 06:06 PM   #4
weissguy
weissguy is a jewel in the roughweissguy is a jewel in the roughweissguy is a jewel in the roughweissguy is a jewel in the roughweissguy is a jewel in the roughweissguy is a jewel in the roughweissguy is a jewel in the roughweissguy is a jewel in the rough
What does the PAIRC-Solenoid valve do?
weissguy is offline   Reply With Quote
Old 07-31-2008, 06:08 PM   #5
MangoDorifto
MangoDorifto's Avatar
MangoDorifto is an unknown quantity at this point
I believe that would be for your emissions system for your KA
MangoDorifto is offline   Reply With Quote
Old 07-31-2008, 06:11 PM   #6
JDM_eightSIX
Ok I am doing a Sr20det swap and I guess my question really is do I need these 3 wires?
Old 07-31-2008, 06:20 PM   #7
YucA
YucA's Avatar
YucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of light
Bottom wire is for the AC. If you dont have ac, you dont need any of those.
YucA is offline   Reply With Quote
Old 07-31-2008, 07:31 PM   #8
Sileighty_85
Sileighty_85's Avatar
Should be Power Steering Idle Pressure switch and A/C Clutch
But the A/C one looks different from other ones.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 08-01-2008, 12:31 PM   #9
JDM_eightSIX
So I can cut the bottom A/C white plug but keep the other 2?
Old 08-01-2008, 12:35 PM   #10
burnsauto
burnsauto's Avatar
burnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfectionburnsauto is close to perfection
Send a message via AIM to burnsauto
You don't really need any of them if you're not running AC..
ps sensor isnt needed.
burnsauto is offline   Reply With Quote
