10-03-2013, 07:14 AM | #1 |
SR20 90mm throttle bodies
I just picked up an aftermarket intake manifold/plenum for my non-vvt sr20.
It has a monster 90mm intake. I didnt get a throttle body with it so have been looking into them. Im wondering if a 90mm TB will be too much for my setup and kill throttle response and lag/torque etc. Car will be used drifting on track. Spec is as follows: Trust TD06-l2 20g turbo 8cm exh. Tomei 260 procams Forged bottom end Around 1.4 bar boost Would i be better off fitting a new flange and using a 70mm throttle body? Or will 90mm be ok? Thanks.
https://www.facebook.com/thrwdown?fref=ts |
10-03-2013, 11:11 AM | #2 |
A 90mm throttle body would be titties on your setup. Better throttle response and better gas mileage and more power etc.
Sent from my iPhone using Tapatalk - now Free |
10-03-2013, 01:49 PM | #3 |
I have a q45 non ecs throttle body with TPS pigtails which i believe is what that manifold was intended for. PM for a good price =)
10-03-2013, 08:22 PM | #4 |
i was looking for an option too ... my manifold is made with a q45 flange but i tought i was overkill tu run a 90mm throttle body on a 450whp sr20vet
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
