Old 10-08-2019, 02:55 AM   #1
Tip315
Tip315 is an unknown quantity at this point
Just bought a 240
I bought a 1993 240sx and my problem is that the engine keeps flooding with fuel I’m getting compression I’m getting spark when I crank the engine it keeps trying to start but won’t turn over and the injectors don’t leak you can’t just hear the gas filling up the cylinders
Tip315 is offline   Reply With Quote
Old 10-08-2019, 06:23 AM   #2
EFITTZY
EFITTZY's Avatar
Okay at least you got it in the right section... so I will bite.
Check your injector o-rings.
They are a common point of failure causing excess fuel to seep into the cylinder and flood it w fuel. Cheap and easy to replace, if you haven't done so already
We do have a small question thread for this very reason...
https://zilvia.net/f/showthread.php?t=297481&page=762
(づ。◕‿‿◕。)づ T E A M B L O O M
Old 10-08-2019, 01:37 PM   #3
Tip315
Tried what you said still didn’t work
Old 10-08-2019, 01:53 PM   #4
S14rebuild
So what your sayn to be clear is, the engine turns over, your getting spark and fuel, but way too much gas is entering the cylinder?
Old 10-08-2019, 02:04 PM   #5
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
remove the fuel rail from the intake manifold, while leaving the fuel lines attached.
Cycle the key to the "on" position, but do not crank the engine.
Inspect the fuel rail for leakage.
Also, are you running an aftermarket FPR?
Old 10-08-2019, 04:10 PM   #6
Tip315
So when I try to crank the car basically it makes this pumping noise and the rpm gauge starts to flicker like it’s trying to start but won’t
Old 10-08-2019, 04:26 PM   #7
S14rebuild
Oh god......
You have spark at the plugs?
Do you have fuel pressure?
Are your injectors firing?
Lets keep this simple
Old 10-08-2019, 04:34 PM   #8
brndck
brndck's Avatar
Oh god......
FAST
Fuel
Air
Spark
Timing
Old 10-08-2019, 04:38 PM   #9
S14rebuild
Yup^ was to lazy to type that out.
Think ima just copy paste cause gotta keep sayn that over and over in the tech section. Should just be a sticky..solve 90% of issuse here
Old 10-10-2019, 09:28 AM   #10
Kingtal0n
Kingtal0n's Avatar
oh god
"I just bought a 240, the oldest, most needy bitch on the planet.... and I want to daily drive it now. btw whats a spark plug? and how does fuel injector work "
Old 10-10-2019, 09:57 AM   #11
S14rebuild
Lmfao hahaha
Old 11-05-2019, 07:53 PM   #12
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Stuck fuel injector. It must be replace. Take your fuel rail out but not the injector and turn ignition on. There should be no fuel spraying and no leak on any fuel unjector.
kennedy8383 is offline   Reply With Quote
