Update
OK so i have my Cody ACE bracket installed, oil pan installed, engine is now in the car..ill be posting pics once i reduce the size of them and make a photo bucket account so i can embed...will be posting soon!
i don't know how to get the pics embedded...I tried but i get the little blue box with a question mark...sorry guys
Also if any of you have creaking suspension use white lithium grease spray...mine was squeaking/creaking bad and the lituim grease made it disappear for now...my ball joints are bad...doing all 4 soon.. Last edited by bmar19; 01-29-2016 at 10:20 PM.. |
when you add the image, don't use it as a link/attachment. on photobucket there should be a code on the right saying IMG, where you can copy and paste the image onto your post. the photo should show. before submitting a post look at a preview post if the pictures showed up or not.
![]() Join Date: May 2011
If you have energy suspension/or polyurethane bushings they might not have been installed correctly/with suspension at the correct height or you just need to grease them up again.
Yeah I have energy. Just for the subframe and my diff. The creaking was coming from the suspension arm bushings which are still stock. I'm pretty sure it was from those. Or the away bar bushings.
