Old 03-06-2009, 02:59 AM   #1
nissan240
nissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to allnissan240 is a name known to all
is my turbo going bad? or my motor?
long story short piston ring went on me one night i was coming from work!
i got it rebuilt(will list mods on bottom) from a pretty reputably guy. dont want to start bashing him or his shop so keep at that for now! got my car back from the shop installed it and now its blowing black bluish smoke! my turbo was good when the rings went out! now my question is, is my motor still good? or my turbo from sitting a bizzlion years? did oil(20w50) get into my rings already after just firing it up for about ten min? havent taken turbo off to see if theres any oil on turbo yet! did a compression test but was low! what i remember if a motor is freshly rebuilt or built it should have all low compression unitl all the ring seats! also it only blows smoke at idle, whenever i keep it at a steady rev at about 3g smokes goes away! havent driven it out of driveway yet!
as for mods here it goes
head:
3angle valve job(portmatch)
bc valves srings and retainers
tomei 256 by 256 camshafts
freddy mani
arp head studs
ngk iridium plugs heat range 8(didnt re-gap, it was already pre-gapped)
greddy rocker arm stopper
cosworth head gasket 1.2mm
oem intake and exhaust valve stem
hks gt-rs turbo
block:
eagle h-beam rods
cp 86.5mm pistons
oem main seals
acl rod main bearing
edged and knifed crank fully balanced
oem water/oil pump
oem timing chain
hot tanked
oem gasket set
any suggestions would help!!! thanks
nissan240 is offline   Reply With Quote
Old 03-06-2009, 04:08 AM   #2
drifter_for_life06
drifter_for_life06's Avatar
drifter_for_life06 is making a name for him/her selfdrifter_for_life06 is making a name for him/her self
Send a message via AIM to drifter_for_life06 Send a message via Yahoo to drifter_for_life06
my car blows black smoke all the time....but thats just cuz its boosted and running rich
RPS13: +.020" 2871r 264's AEM EMS
http://enjukuracing.com/#_l_4s
drifter_for_life06 is offline   Reply With Quote
Old 03-06-2009, 07:45 AM   #3
Z33dori
Z33dori's Avatar
black = fuel, your obvisouly running rich aka 90% of all sr b/c they are not tuned
blue = oil, prolly from your turbo. It might just be blow by b/c aren't fully set..
since it's only at idle i'm guessing you rings are still seating. since it goes away at high rpms.... but i could be way wrong...
Old 03-07-2009, 03:30 AM   #4
nissan240
update....
my turbo seems to be good! but still smoke. i dont want to risk driving around unitl i know forsure whats the problem! i have a fuel pressure guage and its reading 36psi which is normal i believe!! anymore suggestions?
Old 03-07-2009, 03:48 AM   #5
S14DB
AFC #1
S14DB's Avatar
Why 20w50?
Old 03-07-2009, 10:42 AM   #6
drifter_for_life06
is your catchcan full?
Old 03-08-2009, 01:50 PM   #7
nissan240
no my oil catch is empty right now!!
i need to run thick oil 20w50 until i break in my motor then use fully synthetic!
Old 03-08-2009, 05:11 PM   #8
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
do a compression check...what numbers are you seeing? As far as the turbo, how do you know its good? Did you check for shaftplay? Could be the seal fucking up...
CLICK HERE!!!
Old 03-08-2009, 05:56 PM   #9
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Drive the car and let the rings seat and get back to us... has the car drivin under its own power since the rebuild, or is it just sat and idled?
Ceepo is offline   Reply With Quote
Old 03-10-2009, 01:07 PM   #10
nissan240
no shaftplay or signs of oil at all!
cars just sat and idle the whole time
Old 03-10-2009, 01:25 PM   #11
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
[quote=blue = oil, prolly from your turbo. It might just be blow by b/c aren't fully set..
quote]
this is most likely the problem.... i had the same thing on a coupleof my rebuilds...but it went away after the driving the cars for a while. if u take of ur turbo elbow and there is no oil gunked up around the wheel on the exhuast side then its a 99% chance its just a liltte blow by.
fcdrifter20 is offline   Reply With Quote
