03-30-2009, 12:56 PM | #1 |
Q45 rear brakes on s13??
so on my car i have front q45 brakes up front and stock rear with steel lines all the way around. car stops incredible... but this weekend i was at the junkyard and was scoping out the rear brakes with drums a couple of q45 cars were there. they almost look the same as z32 except they have a sliding caliper. does anyone know or have done this swap on a s13/14??? any info is helpful...
03-30-2009, 03:18 PM | #4 | |
03-30-2009, 03:22 PM | #5 |
i dont know if the rotor is the same (caliper mating surface) but the drum is the same, you can use all parts, except the cables, use z32 for s-13 and r-33 for s-14
03-30-2009, 03:28 PM | #6 |
Same parts as the Z32. Direct swap over. The hub though does NOT work.
03-30-2009, 03:30 PM | #7 | |
WHAT??? Z-32 uses drum for ebrake, S-13 does NOT J-30 also uses internal drum But upright is different and e-brake cable is also mounted differntly, if you want to use this set-up IIRC u have to use entire upright
03-30-2009, 03:46 PM | #8 |
cool!! since everything bolts up from a Q45, im pretty sure that the stock s13 calipers wont work. (duh!) so will i be able to use the Q45 rear calipers for now?? then later i can upgrade to z32 rear calipers right? what do i do about the e brake cable? have one made right?
03-30-2009, 04:41 PM | #9 |
Yes. Use the Q45 rotors/calipers. Use the Q45 hardware for the ebrake and use a Z32 or R33 cable, or cut/splice the Q45s.
