01-22-2013, 05:18 PM | #32 |
Alrite, so I realized that the small things that are wrong with the car, things that I learned to look over or stuff that never really bothered me, may be the reason why some people may not want the car... So I'll go ahead and disclose as much as I can.
Then if you are still interested in the car, you can hit me up. Either way, my price still stands at $4500 firm. Here's the list. - Trunk does not open from the trunk release lever next to the driver seat. You have to open the trunk with the key. - Hood release lever broke so the cable to open the hood is cut about 1 foot from the hood itself. You just have to yank on the cable to open the hood. No problems opening the hood whatsoever however you probably would want to fix this or get hood pins if you plan on dailying the car. - Gauge cluster lights are out, this is an easy fix. I just haven't had the time to replace the 3 bulbs (~$5) - RPM needle on the gauge cluster bounces around. I think you may just need to resolder some points on the back of the gauge but not sure. There are some threads on zilvia about this. - Body shop who painted the car drilled screws into the body to mount the side skirts and the rear bumper. I took the screws out for now but there are holes in the body. (this one does bug the hell out of me but I stopped caring). Also, the shop used red primer under the black paint so where ever there are paint imperfections, you can see the red primer. (2 round areas on the driver side from car getting egged, underneath the side part of the rear bumper, under the side skirts). Also, the paint on the body of the car underneath the rear bumper and side skirts is pretty rough looking. It might look ugly without a body kit. - Front end does not line up perfectly. It looks fine from 2-3 feet but if you really look at it, the lines are slightly off. With all that said, as you can see in the pictures, it still looks pretty dang nice and the engine runs fine and never gives me any problems.
