Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
#31 |
![]() Join Date: Sep 2006
305's are huge. We're contemplating 305's as well but we will need wide body for that. 255/45's and we had to bang and pull to get them not to rub. I would agree with Ace in sticking with a smaller tire, but damn 285's are still pretty big. For some reason my manhood feels challenged. LOL.
-Jon
![]() momentumgt.com - "building blocks of speed" |
#32 |
Hello gents ,yea I too think 305s are a bit much . If your dead set on going to a bigger tire, first take temps of the current set up to see if your even geting them to their optimal operating temp9 OUT/MID/INNER.305 in front is gonna have increase the scrub radius quite a bit, as stated before
Hello MOMENTUM GT- The idea you have makes sence,maybe if you get a bracket that has multiple holes in it then you can test & tune to find the desired angle of the RLCA to tune in anti squat. Or if you put the whole subframe on more of an angle. Im not too sure how it would operate because when I think anti squat I automatically invision a 3 or 4 link type suspension & we have indipendant arms. Have you considered the big bar soft spring theory(Carrol Smith). Find a spring rate that offers the desired squat characteristics(rear) VS some roll resistance ,Then use the sway bar to to ultimatly tune Roll characteristics F & R. Didnt you say your on stock sways, also make sure you sway bar is not under pre load. I cut & shortened my front end links,& used a generick energy suspension rear end link kit with the correct length bolt so that the sway bar is parralell under static load & it made a huge differance in handling characteristics( More stable under side loading) .I think this will help the rear squat cause the bar is not in twist before its even loaded. PEACE P.S. Glad to see some real talk going on in the motorsports section. Keep it goin guys.
![]() MR JACKSON. |
#33 | |
Autox Technician
![]() Join Date: Dec 2001
What happens is this: as your rear suspension travels, your spindle's vertical alignment (rotation about the axle) is controlled primarily by the upper trailing arm. What I've found is that shortening the arm increases the forward rotation, which negates the natural anti-squat. This of course is a scratch pad analysis, but it seems to work in practice.
#34 | |
Autox Technician
#35 |
![]() Join Date: Feb 2004
A front airdam alone, on a NASCAR at 112mph with a 200mm ride height and a 100mm airdam, has a coefficient of downforce (CD) five times greater than stock. It also increases rear lift by almost 20%, but the total CD is about three times greater. Drag decreases by about 10%.
The addition of a 100mm splitter to this airdam netted another 10% increase in total downforce, and yet another increase in rear lift. Drag decreased across the body, wheels, and airdam but increased in the underfloor area. However, pitch sensitivity is increased, and a car at my car's stiffness level may very well experience it. Adding a diffuser to the airdam/splitter combo yielded another 3.9% increase in overall downforce but a 1.4% increase in drag, again mostly from the dirty underfloor area. What about canards/dive plates? They're generally regraded as not being terribly efficient but can have secondary effects like the generation of a vortex down the sides of the car and reducing air spillover under the car, leading to more efficient downforce production from the undertray. That's all I'm going to write now because I want to go work on my car, and I take none of the credit for the tests done or for the gist of the paraphrased paragraphs. All credit is to Simon McBeath and all information can be found in Competition Car Aerodynamics. I'll start writing about rear wings and whatnot probably tonight or tomorrow. I figure if I get this out there, maybe someone else can shed some more light. |
#36 | |
As far as front grip goes....how do you guys tune for the dynamic camber curve of a machperson strut suspension? I sold my 240, but on my GTI, I had to throw on custom spindles to move the lower control arm ends down, so that they are parallel to the ground. The roll center moves up above ground, and the dynamic camber curve looks much better this way. Instead of really fat tires, maybe someone could mess around with balljoint spacers on a 240. Keep in mind that the 997 GT2 uses 235s up front, which I suppose has gotta mean something.. ![]() |
#37 | |
![]() Join Date: Sep 2004
Hopefuly this winter ill be doing the same to my S13 Flat Bottom FTW ![]() |
#38 | ||||
Autox Technician
#39 |
Word Ace. Hell, the older Turbos were running 205/55s in the front and 225/50s out back. Just because a car comes with a certain tire from the factory doesn't mean it's the best setup. Also, I would guess that the GT2 will come from the factory with P-Zero Corsas and I would also guess that running 235s will allow the car to understeer more, making it safer for the morons who insist on buying a GT2 despite the fact they can't drive for shit. Oh, and the wheelwells just aren't that big on Porsches.
Balljoint spacers won't just magically make more grip than a wider tire. I have a fairly decent camber curve because I adjusted the angle of my LCAs, but it's still not optimal. I just run lots of camber. |
#40 |
So has anyone ever thought about, what if you have a sunroof car and you decide to lift it upwards, not open it completely but have it so it's angled up facing the wind, how would that affect the car? good downforce? haha
And Sasha's car only has 320whp? I thought it had a lot more haha thats pretty crazy, Do you know how much his car weights? Does he have the B-magic hood? size tires he's running? haha
http://www.amazon.com/gp/prod Amazon book! |
#41 | |
If the angle of the lcas isn't optimal, I suggest maybe hiking the front end of the car up about an inch if you have coils. Then test to see if the front end feels more planted. |
#42 | |
-Jon
#43 | |
-Jon
#45 | ||||||||||
Sorry, I missed a lot, this might be a little long.
As for changing the rear geometry, this is something I have thought about. What I was thinking was leveling out the lower control arm and possibly messing with the mounting points for the upper arms. There's a lot to consider when you do something like this though, so be careful. And make sure to check that there is no bushing bind through the usable range of suspension travel after modifying anything. The amount of anti-squat that the suspension will see depends on the angles of the arms and where they intersect. It's the same thing as roll center, it's just looking at the car from the side rather than the front. It does the same thing. It determines the amount of load transfer that goes through the suspension members and the amount that goes through the shock/spring. I would do some measuring first and see where things lie before changing too much. Obviously, there is a good amount of anti-squat already designed into the suspension. You could get rid of all of it by making the upper and lower arms parallel to each other. But this is probably something that we should start another thread about. Quote:
There are also other ways you can measure the effects of an aero package. If you can find a long smooth road and a calm day, you get an estimate of the max downforce the car will produce by looking at shock travel. But search around, and I'm sure there's some good ideas in the books you just got, but there's a good amount of testing you can do without having to spend a ton of money. And coming up with a good plan is the only way to do this effectively in terms of both cost and performance. Quote:
As for Jon's idea, fabbing a bracket with multiple holes could be a good way to test, but I still think a lot of measuring and running numbers is the best way to get in the ball park and then maybe some fine tuning afterwards. As for "small spring, big bar," I don't believe Carroll Smith advocated that idea. I know he mentioned it and said it was common for a lot of people to run, but I don't think he ever said he actually liked it. He did say to run the softest springs that you can get away with and then balance out the lateral load transfer with the sway bars. This doesn't mean to run soft springs and really stiff bars. Personally, I like to run the spring rate that you need, and then use as small a sway bar as possible just so you can adjust oversteer/understeer. And like Aceinhole said after you, there is no way to preload a sway bar that would actually be good for handling. Unless you're only turning in one direction. Because the bar has to twist clockwise to turn one way and then to turn the other way it has to pass the neutral position and then rotate counterclockwise. Quote:
Depending on what spring rates you're running and how low the car is and how much wheel travel you're going to see, you can determine what amount of camber you need to run to keep things balanced when cornering. Usually it ends up being a lot of camber. But like Aceinhole said, you can get away with a little less static camber depending on your caster. As you turn the wheel a lot of things happen, depending on your caster angle, the outside wheel will gain camber with steer angle, but due to kingpin angle, the outside wheel will lose camber due to steer angle. And then depending on wheel travel and suspension, when cornering, the outside wheel will usually lose camber relative to the road because the body will roll more than the wheel will gain camber, but sometime with a MacP strut setup, the wheel will be gaining camber already and it will amplify the effects of the roll camber gain. So it's kind of a mess. As far as tire size, that also depends on a lot of things. Suspension geometry, spring rates, vehicle mass, etc, so it's hard to compare one car, which is totally different in pretty much everything, to another car. It's like comparing spring rates or sway bar size or anything like that. Quote:
Alright, well I think that's it, sorry for it being so long. Tim |
#46 |
![]() Join Date: Jul 2007
Trader Rating: (106)
Under 90mph any aerodynamic downforce created will only have a mild affect on the car, trust me my dad ran several formula atlantic cars over a 10 year time period and we did TONS of aero testing. That's not to say that it will do nothing at all, it will just be minor. If you really want to improve the aerodynamic performance at those speeds add some underplating and diffusers to reduce drag.
#47 |
Hello,hello. As far as the preload thing goes I wasnt saying to preload the bar,just to make sure there is not any twist /bind it it before its under load.Kinda my idea of preloding, but not the true definition of the term in this case. Good points carry on,carry on!!!!!
![]() MR JACKSON. |
#48 |
![]() Join Date: Apr 2004
If you're really serious about it, you can build a scale model of your car and experiment in a small wind tunnel. It's not the real deal but it's much much cheaper than a full scale wind tunnel.
But the small tunnel is still expensive for me so I don't know what to say. |
#49 |
There's a million better ways to spend his time and money and probably get more out of it than making a scale model of his car and running it in a wind tunnel. He would be better off, making a CFD model and using that as a tool to analyze the aerodynamic performance of his car before messing with wind tunnel testing. There's also tons of on the track and less sophisticated testing that he can do that will give him more gains/time or per dollar than wind tunnel testing would. It's just not a good solution for someone on a budget especially when there are so many other, better options out there.
Tim |
#50 | |
It'll save cardboard boxes from becoming patterns, at least, and if it's not perfect I can always adjust. |
#51 |
![]() Join Date: Nov 2005
http://www.voltex.ne.jp/english/witem/witem.html
Just a random plug here, but Voltex wings are designed and tested with a wind tunnel. In case you're still looking for a wing. I think I'm going to have to read through this thread a couple times.
#52 | |
#53 | |
I was talking about buying an off-the-shelf 1/24 Silvia plastic model, Tim. |
#54 |
You are gunna need front downforce as well before you just throw a wing on anyways or else you will have high speed understeer. I think you should concentrate on the undertrays, diffusers, and splitters first and then go from there. If you do too much at once you won't know what works and what doesn't.
#57 |
it simply sounds like he needs/wants more front grip in the slower corners, so any time or aero i dont believe would make a significant difference. i say just alil more front camber with overall R-compounds i think would be suffice. maybe slightly stiffer rear sway bars too.....
#58 |
This is going to sound pretty ridiculous to some of you guys, but i know its worked in the past.... I cant remember exactly who did it, but someone put carpet underneath their car, and it was so effective they banned it the next year completely. I think i recall it was a lower powered/lower speed class and just some dude had this idea to completely eliminate the air moving under the car, so thats what he did. He basically attached a piece of carpet, cut in the shape of an undertray, to the front of the front bumper where the front lip would attach, and then let it hang down and drag the ground. Obviously it needed to be clear of the wheels and suspension components up front. Then he attached another piece in the center body of the car, behind the front wheels, let it drag the ground, and the same for the rear. Now i dont know exactly what would be involved in this but from what i recall it did amazingly for such a simple/cheap mod. Of course it would wear out quicker than an aluminum undertray but at its cost, it could be replaced every race with minimal costs.... An added benefit is that the carpet could catch 95% of the fluids that may drip on the track, from engine, cooling system, transmission, etc. Although it may have spewed carpet fibers all over the track, they are a hundred times less detrimental to traction than oils/fluids are...
Seems like that would be the cheapest, most effective "aero" mod he could do at the speeds he is talking about, which is the topic of this thread started by the OP.(low speed aero on a budget) I know all you guys are telling him buy this, change that, but he was asking about aero in low speed, so thats why i posted this.... again i know its ridiculous but no flaming please..........
