06-10-2011, 04:59 PM | #1 |
S13 must have gas pedal pressed to start. MANUAL
Hi im posting for a friend who says in order to start his car he must have his gas pedal with his clutch pressed to start his car, i figured i could ask on here and see what comes up i went through the first five pages and searched under the advanced search option and didnt find anything other than vaccuum but seems to be something more than that cause we have search and listened and found nothing 3 times over. dont have a vaccuum compression tester but ya seeing if it might be anything else thanks guys
eatSleepDRIFT |
06-10-2011, 06:30 PM | #3 |
Is it must have pedal depressed to get car to crank or to get car to actually run?
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp |
06-30-2011, 11:39 AM | #5 |
I'm having the same issue with mine. I have to hold in the gas pedal otherwise it just clicks and won't turn over.
Could it possibly be the spark plugs are fouled? |
08-01-2011, 05:55 AM | #8 |
Bump still having this issue, replaced the battery because it was bad. No kill switch under the pedal.
And when it does start after a few tries, it idles really low at about 500 rpms and bounches between 500-700 and then after it warms up goes to 1000rpm or so at idle. I already cleaned the MAF/intake to check that. |
08-01-2011, 05:12 PM | #11 |
Fixed my issue.
Hose connecting the fuel pump to the line was ruptured. That would explain the low PSI on my FPR. Installed new pump/hose and adjusted the FPR to 43 and it runs fine. |
