Old 01-12-2014, 11:49 AM   #1
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
S14 KA24DE Koyo- low engine temps + other question
I installed a koyo onto my ka24de.
Bought it because it was a good performance mod, I thought it looked cool, and it was cheap.
Everything worked okay, but now my car doesn't look like it's getting to operating temp.
The needle barely goes past the first line. I put a piece of cardboard in front of the radiator to warm it up. And it worked for a while.
Now I noticed a coolant leak under my car towards the back. I'm not sure if it's related to the cardboard, so I removed it for the time being.
Has anyone else had the same problem? Any advice?
Anyone know where the leak is coming from possibly? Maybe the heater line on the back? I just want to get an idea of where to look first. Thanks!
Old 01-13-2014, 08:24 AM   #2
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
Put a thermostat in if you don't have one installed.
I like my bikes how I like my b¡tches...naked!
2014 Triumph Street Triple
kruked is offline   Reply With Quote
Old 01-13-2014, 01:19 PM   #3
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
I have a thermo, but it might be old. I didn't change it when I changed the water pump
Old 03-06-2015, 08:19 AM   #4
FaLKoN240
FaLKoN240's Avatar
Trader Rating: (73)
It was a bad thermo. Stuck open.
Old 03-06-2015, 10:10 AM   #5
kruked
Trader Rating: (37)
Glad that you found the reason.
Old 03-06-2015, 04:55 PM   #6
underscorerobbie
underscorerobbie's Avatar
underscorerobbie is an unknown quantity at this point
I had a thermo stuck open in mine, so I replaced it, bled the air out for at least 25 minutes, and it still overheated, I was told that the ka24de requires an oem thermostat rather than one from a parts store? Is that true? It sucks not having heat
underscorerobbie is offline   Reply With Quote
