some problems with fresh swap...HELP!
well me and a friend put in a complete rebuilt block and head. everything came together good. but heres a couple problems that we ran into:
-a turbo line( i think the water line) is leaking coolant bad. but it seems tight. should i keep tightening it or something else? -Also, when we tried to start the car, it sounded like it wasnt timed right, how do i go about finding it all out? -last but not least, i put in a ACT extreme 6-puck clutch, and i took the damper box out and the clutch still seems weak and soft. and when i started the car, the clutch just stayed on the floor, and the slave cylinder is brand new? what could that be. i searched but didnt really find good info. thanks |
![]() Join Date: Dec 2005
Location: Formerly Elk Grove/the916/95758/NorCal - Now teh 970
check the line for holes. i had a coolant line that had a hole small enough that you couldnt see until things got warmed up and the line got warm. boy it was a pain in the ass.
yea, the bolt for the turbo line was a PITA to get in. it was a real tight fit, hopefully i could get away with just tightening it, but thats not my luck with this car.
#4 | |
Man w/ CTSV & a Car Seat
Timing, umm...FSM, only way to do it. Did you follow the FSM to the T when you put in the timing chain??? Clutch line...keep bleeding it, it shouldnt go to the ground unless you got the wrong TOB. Would suck if it is...cuz they you'd have to drop the tranny to fix it... |
i'll take the bolt out and check, i never put it in in the first place, it was my friend.
i have the FSM(wouldnt be close to done without it) come to think about it, my friend set the timing on that to...i think i am seeing a pattern here. and i know i put the clutch on the block right, but i thinking it has something to do with the fork or the TOB, |
![]() Join Date: Jul 2008
is this your car or your friends cuz i dont let my friends touch my 240 let alone my engine to much money invested and things that if they broke they would not fix
hey, i think i found out one of my problems...for the turbo line bolt..if it really really important if it has a washer? i looked and checked it out and it's not stripped out. would a washer there help it out?
AFC #1
![]() Join Date: Oct 2003
Yeah, you need the double washer on the banjo bolt.
Did you bleed the clutch line when you installed?
Comments should be taken as Opinions not as Statements of Fact ![]() |
