Old 03-05-2014, 02:43 AM   #1
lowz 94
lowz 94 is an unknown quantity at this point
s13 blacktop fuel cut during low acceleration need help!
like the title says i have a s13 blacktop i just recently swapped it in. it runs great at idle will rev up and build boost in neutral. now when i try to take it out on the road it gets to about 2000 to 3000rpm im guessing. (tach doesnt work i need to get a dohc tach) then hits fuel cut and either drops down in rpm then kicks back in or it just shuts the motor off completely. i have dug around for vac leaks and cannot find one. i have a walbro 255, new FPR, new ngk iridium plugs, new chasebays harness, and new greddy profec boost controller. would love some more ideas to trouble shoot.
lowz 94 is offline   Reply With Quote
Old 03-05-2014, 07:43 AM   #2
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
see it is posts like this that make me hope and pray my blacktop s13 sr20det runs correctly. I just picked my swap up a few days ago and am about to order a wiring specialties pre made harness. my swap is going in my zenki s14
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 03-05-2014, 08:19 AM   #3
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
Check the ECU for codes? Sounds like a MAF voltage low problem which puts the ECU in limp mode (actually switches to alpha-N and limits rpm to 3000).
OnTheChip is offline   Reply With Quote
Old 03-05-2014, 09:20 PM   #4
cotbu
cotbu's Avatar
Your building boost in neutral? not possible, unless timing is so retarded it allows yo to do so. Check ecu for codes and verify base and idle timing. If it's also mafs you should have mentioned the jerking back and forth while driving, when you try to rev above 2500 also black smoke could be present.
Old 03-05-2014, 10:12 PM   #5
lowz 94
It wont build boost I mean spike like a pound or 2. Ecu reads 55 normal. And tried 2 mafs and unplugged and there was a difference so maf is functioning thers no jerking just either fuel or ignition cut
Sent from my SGH-M919 using Tapatalk
Old 03-06-2014, 01:28 AM   #6
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
Start with a boost leak test my friend. Will work wonders for you
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 03-14-2014, 06:03 PM   #7
lowz 94
okay did a boost leak test and no leaks. what next?
