Old 10-18-2010, 06:43 PM   #1
surferdon
surferdon's Avatar
surferdon is an unknown quantity at this point
s13 Ka24de 2 questions!
Hey, I am new to the forum, and new to the 240. I just bought one and it has two issues.
The first issue is that there is something that is draining the battery and I am not sure what it is. I was thinking it was the alternator, but when I pull the negative off the battery, the car still runs... Any IDeas??
Second, The car is I believe is burning oil because I notice white smoke coming out of the tail pipe, and It smells a little off. I have changed the spark plugs and wires, and I was wondering what else I should do. Im doing an oil change tomorrow, but I don't think that will make a difference on this issue.
Any help would be much appreciated
surferdon is offline   Reply With Quote
Old 10-18-2010, 06:46 PM   #2
benarovi
benarovi is an unknown quantity at this point
its a ka there old and shitty they gonna smoke a lil. try seafoaming it see if it helps. and the alternator thing idk maybe ur batterys old or lost a little charge, or you gotta light on somewhere
benarovi is offline   Reply With Quote
Old 10-19-2010, 12:29 AM   #3
Rabboni
Rabboni is an unknown quantity at this point
White smoke is caused by burning coolant. Watch your coolant levels, and watch for coolant in the oil.
To find your parasitic drain just hook up your ammeter to your battery and start pulling fuses. when you pull a fuse and the amp draw decreases then you found the circuit that is draining your battery.
Baling Wire-The Duct Tape Of Champions
Rabboni is offline   Reply With Quote
Old 10-19-2010, 12:06 PM   #4
surferdon
surferdon's Avatar
Thank you Rabboni! That is very helpful information.
Old 10-19-2010, 12:36 PM   #5
Walperstyle
Walperstyle's Avatar
Please do not come into the Tech Section to post comments for at least 10 more years.
KA-T ORG-Function over Flush
Old 10-20-2010, 11:22 AM   #6
surferdon
surferdon's Avatar
My sentiments exactly
Old 10-20-2010, 01:45 PM   #7
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
dannnnngggg
c-los13 is offline   Reply With Quote
Old 10-20-2010, 01:47 PM   #8
c-los13
c-los13's Avatar
i agree
about your white smoke problem....worst come to worst it could just be the head gasket
change that sh#%^t!!!!
Old 10-20-2010, 02:18 PM   #9
Walperstyle
my car doesn't smoke.
Old 02-22-2011, 08:32 PM   #10
qwerth
qwerth's Avatar
Trader Rating: (25)
qwerth is an unknown quantity at this point
Feedback Score: 25 reviews
did you get it fixed? my friend has a similar problem
qwerth is offline   Reply With Quote
