Old 02-05-2011, 11:29 PM   #1
bigjacsoc
bigjacsoc is an unknown quantity at this point
SR SR Won't Boost Over 6psi
I had a manual boost controller for a while and I was able to get the boost up to 8-9psi but wouldn't go any lower or higher no matter how much I changed the MBC. I even took the MBC out and ran it stock and only hit 6psi.
I figured my MBC crapped out and just got a GReddy Profec B Spec II all hooked up correctly and at 0% it boosts to 5.9 and at 20%, 35%, and 40% it hit 6.2psi which is a negligible difference.
WTF? Any answers? Anyone had this problem before?
bigjacsoc is offline   Reply With Quote
Old 02-05-2011, 11:31 PM   #2
bigjacsoc
Old 02-05-2011, 11:48 PM   #3
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
get a new wastegate actuator the springs wear out after time, had similar trouble. put a new WGA on and it works like a dream. seeif that works.
ultimateirving is offline   Reply With Quote
Old 02-06-2011, 12:28 AM   #4
bigjacsoc
I figured this is what could be doing it. Does anyone know if I vacuum leak would do it? I mean there was no difference between 0% and 40% in boost. I have pressure checked all vacuum lines and coupler, only thing that could be causing a leak is something stupid like a bad gasket, or something with the stock recirculating BOV and SMIC.
Old 02-06-2011, 02:22 PM   #5
bigjacsoc
Bump why is this message not long enough?
Old 02-07-2011, 07:22 PM   #6
JayZeeSILVIA
JayZeeSILVIA's Avatar
JayZeeSILVIA is an unknown quantity at this point
sounds like a bad wastegate spring
SKUNKWORKZ BUILT
JayZeeSILVIA is offline   Reply With Quote
Old 02-18-2011, 02:19 PM   #7
bigjacsoc
Bump. Any other ideas?
Old 02-18-2011, 06:41 PM   #8
Kingtal0n
Kingtal0n's Avatar
boost comes from the turbine being spun quick enough to spin the compressor quick enough to accelerate air enough to generate a "backpressure" as air molecules compress against each other as they try to cram into the cylinder/intake/plumbing/intercooler/turbo outlet.
So boost problems can occur for many reasons:
A damaged turbine
A damaged compressor
A boost leak
A bad actuator / poor wastegate signal
the boost leak problem also "occurs" when the compressor runs out of "breath". So for instance, asking why your t-25 cannot hold 15psi of boost at 7000rpm is not a "boost leak" problem (where it is out of compressor actually).
So from easy -> hard check the actuator, check the vacuum routing and boost controller lines, then check boost leaks, then examine the compressor wheel, and finally... the turbine.
Old 02-18-2011, 07:28 PM   #9
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
was your car working fine before all of this. you might have your vacuum for the actuator incorrectly setup
Originally Posted by Jung918
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
