Old 09-21-2012, 03:21 PM   #1
braydo25
braydo25 is an unknown quantity at this point
Relay clicking under dash, pulling a ton of power (Pics) And dome light fuse blowing
I searched before posting. No info that was detailed enough.
My 92 s13 has a clicking relay when switched to on. The car starts and runs but whenever this relay clicks it pulls a ton of power from my battery and surges my idle. It's the lowest black relay, so second from the bottom. It feels a little warm too. My sun roof and stereo aren't coming on either. Does that have anything to do with it? I rewired the entire chassis harness when I reinstalled everything into the car, and I'm pretty sure I connected all the grounds but I may have missed one.. Any ideas?
What circuit is this relay to?
It's the second relay from the bottom, the black circular guy that's clicking - and loud too.
Not sure if it has anything to do with it, but my dome light fuse blows no matter what position my ignition is in as soon as I put a fuse in, and it's a big spark / pop.
Picture:
braydo25 is offline   Reply With Quote
Old 09-24-2012, 08:34 PM   #2
kennedy8383
kennedy8383's Avatar
kennedy8383 is an unknown quantity at this point
Clicking relay meant it's working.. You probably have short, not connected correctly, or wire touching causing electrical issuse somewhere.
kennedy8383 is offline   Reply With Quote
