Old 06-18-2019, 07:53 PM   #1
Lac911
Lac911 is an unknown quantity at this point
Brakes Skyline R33 1993
I'm looking for rotors front and rear with pads for this car.
front 295 x 30mm
rear 290 x 18 mm
What is the Nissan has those rotor and pads?
Lac911 is offline   Reply With Quote
Old 06-19-2019, 07:43 AM   #2
jedi03
IIRC the 93 Skyline has those...jk lol just go to the parts store and tell them you need to measure some rotors then you will have part number...if not I'm sure a google search will show alternate options with slight possibility of needing to have them shipped to you
Old 06-19-2019, 08:25 AM   #3
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
R33 GTS and GTST are 296x30
I haven't found any skyline that uses a 290x18 rear
Old 07-10-2019, 10:24 AM   #4
Lac911
Nissan Skyline R33 1993 Front Brakes
What existing car from Nissan can I found the 30 x 296 mm disc to fit at the front of my Nissan Skyline R33 1993 ?
Old 07-10-2019, 11:24 AM   #5
brndck
brndck's Avatar
i'm not sure if you missed my response
Old 07-10-2019, 12:47 PM   #6
Mikester
Mikester's Avatar
Mikester is a well-known jackass
R32 GT-R (non-VSpec) front rotors are 2mm wider IIRC, but still work perfectly with the R33 GTS/GTSt 4-pot calipers.
R32 GT-R and R33 rear rotors are the exact same as 300ZX (Z32).
Pads: Z32 all the way around.
Mikester is offline   Reply With Quote
Old 07-12-2019, 12:23 PM   #7
Lac911
Nissan Skyline R33 1993 Brakes
Front and rear pads are the same for R32 and R33
Old 07-12-2019, 01:35 PM   #8
Mikester
Mikester's Avatar
Correct- If you have the 4-pot calipers in front and 2-pot calipers in back.
Old 07-12-2019, 02:45 PM   #9
Mikester
Mikester's Avatar
To illustrate, this is my setup.
Front: R32 GT-R (Non-Vspec) 296mmx32mm rotors, R33 GTSt calipers, Z32 pads:
^^This^^ image shows the 32mm width of the GT-R rotor does not interfere with the R33 caliper.
Rear: R32 GT-R rotors, R33 GTSt calipers (same as R32/Z32), Z32 pads
Hope this helps.
Mike
Old 07-12-2019, 03:35 PM   #10
Lac911
Ho yeah
thanks
Old 07-13-2019, 05:18 AM   #11
Corizer
Corizer is an unknown quantity at this point
5 LOCH -> 5 HUB
Z32 26mm Aluminum (1990 NA 300ZX)
280mm x 26mm (5 Loch)
Z32 30mm Aluminum (1990-1992.5 Turbo 300ZX und 1991-1992.5 NA 300ZX)
280mm x 30mm (5 Loch)
Z32 30mm Eisen (1992.5-1996 Turbo und NA 300ZX)
Infiniti J30 1990-1994
280mm x 22mm (5 Loch)
Infiniti Q45 1990-1996 (G50)
280mm x 28mm (5 Loch)
Nissan Sentra 2003~ V-Spec (B15 - Brembo)
305mm x 27mm (4 Loch)
Skyline 1989-1993 GTR (R32)
296mm x 32mm (5 Loch)
Skyline 1993-1994 GTR V-Spec (R32 - Brembo)
324mm x 30mm (5 Loch)
Skyline GTS 1993-1998 (R33)
Skyline 1993-1998 GSTS (R33)
296mm x 30mm (5 Loch)
Skyline 1993-1998 GTR (R33 - Brembo)
Skyline GT 1998-2002 (R34)
Skyline 1998-2002 GTT (R34)
310mm x 30mm (5 Loch)
Skyline 1998-2002 GTR (R34 - Brembo)
350Z 2003~ (Z33, non-track)
296mm x 24mm (5 Loch)
350Z 2003~ (Z33, Track)
Hinterachse:
Z32 (1990-1996 300ZX)
R32 (GTS, GSTS, and GTR 1989 - 1993)
R33 (GTS and GTST 1993-1998 )
R34 (GT, GTT 1998-2002)
297mm x 18mm (5 Loch) mit integrierter Handbremse in der Trommel
S14 240SX Rears (1988-1998 S Chassis)
258mm x 9mm
Corizer is offline   Reply With Quote
