Old 02-29-2016, 09:55 PM   #1
erikforce1
erikforce1 is an unknown quantity at this point
s13 Advice for s13 coupe manual seat belt conversion
I'm aware the easiest conversion would be a full on cdm conversion, but it's hella expensive. I read the next best option will be to use the seat belts from a b14 sentra. For this swap, I know you need the b pillars. Am I able to use sentra a pillars as well? Any advice will be appreciated.
erikforce1 is offline   Reply With Quote
Old 03-01-2016, 12:14 PM   #2
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
It's much easier than you realize. Go to a junkyard and find a non wrecked b14. Pull out all the seatbelt parts, possible a receiver from another vehicle if the b14 are too short. I cut my stock pillars and used the plastic covers from the b14 pillars.
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 03-01-2016, 12:27 PM   #3
erikforce1
what do you by cutting your pillars? what parts do I need exactly? does anyone a write with pictures to help?.I'm trying to figure all this out begore I go to the junkyard and I miss something.
