Old 04-10-2012, 06:50 AM   #31
army240
army240's Avatar
army240 is an unknown quantity at this point
Something like that happened to me...
Started the car, ran good for 15 minutes. Then it started to sputter and died.
Redid all wiring, checked CAS timing like 10 times, checked cam timing, tried another CAS, another igniter, another set of coilpack, checked for spark and fuel... I even tested my wiring with an oscilloscope. Redid all ground too!!! Everything was good...
Then I decided to change the spark plug just because I was out of idea...
Put the new plugs in... started right up. I was soooo pissed that I loosed 3 freaking weeks of nice weather(that we don't have a lot in Quebec) because of stupid spark plugs!!!
It's not because it's doing spark in ambiant air, with no compression pressure, that it is still doing spark in the combustion chamber with pressure and Air and Fuel mixture!!!
It might not be the same thing as me, but I think it worth a try. In 10 years of as an automotive tech, it was the only time I saw that.
I hope it help,
Frank
EDIT : Damn, should have read your last post!!! Good think she fired up, have fun!
Life is a beat to beat
Last edited by army240; 04-10-2012 at 06:51 AM.. Reason: Didn't read everything...
army240 is offline   Reply With Quote
Old 04-10-2012, 10:19 AM   #32
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
Haha. Thanks I do need new coils and colder plugs. And to adjust the timing a little more. I hear you about missing good weather its the same in Idaho. Thankfully I got one drive cause now I'm 400 miles away working
idahotuner is offline   Reply With Quote
