For Sale Items Post items for sale here. ABSOLUTELY NO COMMERCIAL SALES. |
![]() Join Date: Mar 2014
Toyota 2JZGTE VVTI for sale (Rival Auto Works Motor Refresh)
Hey everyone,
Awhile back I planned on swapping this beast into my old S13 project, I had it refreshed with a lot of new parts from driftmotion (I will list below everything that was changed out with new parts). Price: SALE PENDING (Negotiable) Refresh Specs(All parts ordered from Driftmotion): -New Thermostat -New Silicon Turbo couplers -New Gates Timing Belt -New Serpentine Belt for (AC Compressor delete) -New Spark Plugs -New VVTI Cam Gear Rebuild Kit -New 22 Pin connector VVTI -New VVTI Valve cover gasket set -New 2JZGTE Water Pump Assembly -New 1JZ/2JZ Timing belt tensioner -New Toyota Rear Main Seal -New 2JZ Timing belt idler pulley -New Toyota Front Main Seal -New 2JZ Cam Seal -New Xcessive Manufacturing 2JZGTE VVTI to S13 Engine Mounts So roughly $460+ in new parts to ensure the reliability of the motor, not including the cost of the new mounts $95. Motor Specs: -Toyota 2JZGTE VVTI out of an Aristo (Purchased from ICHIBAN JDM in Pico Rivera, in late 2015) -No Auto Transmission (Save you the hassle of removing it) -Don't recall the compression but it was certified 150+ PSI across the board from ICHIBAN, I highly recommend that you check the compression if you're interested. But I doubt it is anything less then 155 PSI since it hasn't been touched in little over a year. -55k miles -Rival Auto Works True TWIN Turbo conversion (Not Sequential) -Simplified and cleaned engine harness Photos: Hit me up if you're interested. Price: SALE PENDING (Negotiable) Last edited by R2RO; 02-08-2017 at 01:05 AM.. |
Tags |
2jz, 2jzgte, drifting, s13, vvti |
